Question about Electric Garden
How to connect the weg motor on a Trimtech electric mower
My trimtech electric lawn mower does not start up but if you turn the motor by hand it starts up.please advise what could be the problem?
cord driven --- problem start / run capacitor
battery --bad contacts , motor bushes wearing out
Apr 09, 2018 | Electric Garden
Where can i buy a 43 cc trimtech brushcutter carburater repair kit
any mower repair shop
from E bay
search in small motor carby kits
there are only 3 makers of carbys ---walbro, zamma and a chinese brand
all manufacturers use one of these brands
Nov 08, 2017 | Televison & Video
I need to find a nearby shop in the eastern cape, where I will be able to buy a brand new piston for a 43cc trimtech brush cutter, please advise.
any mower shop will get what you want
go e-bay
small engine parts and get the piston from there
Nov 04, 2017 | Garden
I have a new Trimtech petrol lawnmower and can not seem to get it to switch off
check the single wire going to the coil. This is the kill wire to the switch.
Sep 03, 2013 | Garden
Electric Lawn Mower Doesn't start - Pwr supply ok - No burnt Moto
this mower has a dc motor and the brush on the black wire to the motor usally wears down
Mar 03, 2010 | Black & Decker 19" Electric Lawnhog...
I have an 24V electric mower.\i charge it
Either the connector between the battries and the mower are bad or the starter switch is bad, you know the wires between the batterries and the connector are good because you said the batterries charged just fine, so either between the connector and the motors, or the key switch has a break in its continuity, easiest way to test is connect the batterries directly to the motor to see if it works if it does connect before the start switch then after the connector the before the connector and keep moving up the connection wires until you fine where the problem is. Hope This Helps Don
Nov 08, 2009 | Black & Decker 19" Electric Lawnhog...
Garden Logo
Top Electric Garden Experts
Steve Oakes
Steve Oakes
dannydoesita
sgtstrat
Level 1 Expert
Are you an Electric Garden Expert? Answer questions, earn points and help others
