Televison & Video Logo
M
Michael Forrest Posted on Nov 22, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Vertical stripes on Samsung 65" 4k tv
Samsung model un65nu6900fxza (t-con board?) I am told there is no t-con board in this set?
Level 3:
  • Samsung Master 19,187 Answers
  • Posted on Nov 22, 2019
Samsung Master
Level 3:
Answers
19187
Questions
0
Helped
4339524
Points
82259
Those lines are usually caused by an edge connection on the actual display. The connection can come loose or get corrosion and then cause lines. To repair this means that you will be taking the unit apart all the way down to the screen and pressing along the edges to see where the bad connection is. There are you tube videos on the problem in general but you have a large screen and it requires special handling and care.
5 Related Answers
Anonymous
  • 608 Answers
  • Posted on Dec 10, 2010
SOURCE: Samsung 46" LCD LN46B650 started showing vertical
had a very similar situation with my Phillips 42 in. LCD TV.
Here was my Problem. The Power Supply Board. I opened it up( Warranty was Expired) and found several faulty capacitors on the PSB. Its pretty common. Major Electronic companies were sold faulty capacitors that fail in 2-5 years instead of 10-20 due to a lack of preservatives. It wouldn't surprise me if you have the same problem. TV will work fine for a few years and then just fail completely or slowly deteriorate.
Here are the solutions
1. Have it Repaired
2. Check for faulty caps and if you find some(budged or leaking) you know you have located a problem
Remove the board and replace the whole thing.
3. If you have some soldering skills you can replace the faulty caps.
Caps are very inexpensive, under a dollar in most cases. I replaced 4 for about $5.00
Hope this Helps.
Good Luck
Anonymous
  • Posted on Feb 27, 2011
SOURCE: Multi-colored vertical lines fade in
Tab Bonding Issue. I too have had this problem with the very same model, it is most often improperly diagnosed as a t-con board issue by most who just want to provide an answer for the sake of there own ego at various forums. This is a manufacturing defect. I have been dealing with Samsung for over a month now and have been offered a replacement model of lesser quality(LN40C650L1F) at a prorated cost of $300.00 to me which I have not accepted as of yet. My TV began having this issue almost exactly 1 year beyond warranty period. Typically it will only happen when TV is cold(if temp in room falls to approx. 68 deg or lower). When cold due to naturally occurring shrinkage as with anything, the tab bonding contacts to the screen are broken and therefore gives you 3 thin horizontal lines across separating the screen into four quadrants vertically and blurry details of everything including channel info, menu info, etc. It goes away after several minutes of warm up time, as the unit warms up expansion of the panel resumes and contact through the defective tab bond is made and picture is back to normal. A quick test to determine this is if you gently squeeze the bezel(frame) around the panel at the top left corner approx. 2 to 4 inches from the corner(this is where the defective tab is located for this particular problem) the problem will go away until the unit is turned off and has ample time to cool off again. When you squeeze you are effectively forcing the tab bonding back together and contact again is made. Another way to diagnose would be to turn your thermostat in house up above 72 degrees or so and wait a few hours for the TV to acclimate to the temp(expand) .This is why if left alone for a few minutes to warm up the problem disappears. Consequently people who keep there homes on the warm side, say above 70 deg. don't often see this problem, but the more heat-cool cycles the units go through the more likely this problem will rear up its ugly head.I believe this defect will pop up eventually on all samsungs produced with the same tab bonding method or materials that were used for however long they were manufactured that way. Naturally everything moves(expands and contracts) through heat-cool cycles but proper engineering methods or materials should prevent something like this from happening for at least, lets say 10 years, the average life expectancy one would expect to get out of a $1500.00 or more purchase depending on screen size. Common sense would dictate larger screens would be more prone to this problem due to more movement and smaller less prone. Unfortunately there are numerous tab bonds all across the top of the screen(panel) and different ones affect different functions of the operation of the set, therefore there may be many other various problems people may be experiencing with there samsungs due to a failure of one of these tab bonds. They are often erroneously diagnosed as circuit board failures due to laziness on the part of the tech. I would recommend to anyone experiencing intermittent or any problems to gently squeeze all along the top of the bezel to locate a defective tab bond. As for dealing with Samsung, all I can say is good luck, it is difficult to reach their corporate office and even more difficult to get a resolution. I would gladly join in any class action lawsuit if brought about as the one regarding their capacitor issue disappeared once they sought to start addressing the issue and this was only after an absurd amount of complaints to the NJ BBB and consumer affairs websites. I think they realize that they have a huge problem with most models manufactured in the last 3-4 years(primarily due to using cheaper components as a cost reduction/profit boosting solution) and as with any large corp., are not willing to issue any recall as it is cheaper to just deal with angry customers on a case by case basis, very unfortunate for them as their sales will suffer terribly because most people research on the web before making major purchases in today,s world and thank god for that.
Anonymous
  • 10594 Answers
  • Posted on Mar 28, 2011
SOURCE: I have a Samsung Ln32A450c1d
Basically it is problem of LCD Panel (screen) however some times T-Con board replacement fixed the issue (T-Con board is part of lcd panel but some part shop sell it separately). Main board is not related with this kind of problem.
Required T-Con board is available in ShopJimmy.com (click the link to view available boards)
If T-Con board replacement does not solve half screen vertical lines problem then LCD Panel will be replaced and it would cost approx new tv price.
Hope this info will help.
Thanks.
Anonymous
  • 879 Answers
  • Posted on Aug 20, 2012
SOURCE: 1 vertical black line on samsung plasma tv on left side (model # pn50a450p1dxza)
Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the left top left corner of the display window. It will make search easy. Some times, the ads attached with each posts both at the right and bottom, might help you to find the availability of spare parts. There are more than 640 posts to different brand TVs now. Will be updated daily. Faults to Samaung Plasma TVs are given in detail.
gopakumarg43
  • 76851 Answers
  • Posted on Mar 07, 2016
SOURCE: Samsung tv es7550 service menu T con usb failure and panel auto setting failure. WD count 1 How can I fix this? I get vertical lines on screen the tv freezes and then reboots on its own.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD screen are similar, irrespective of its brand and screen size.
How to fix my Samsung tv that is flashing white light
There is a good chance you have a bad panel, put the original boards back in the set, unhook the ribbon cables going to the panel boards from the main or tcon, I didn't pull service info so don't know if this set has a tcon board, in either case, remote the ribbon cables going to the panel boards , if the set comes on with backlights, naturally no picture, the panel is bad
Vertical colored stripes on my V555-G1
Vertical colored stripes on your V555-G1 TV can be caused by a few different things. The first thing you should check is the cable that connects your TV to the input source.
Make sure that the cable is firmly connected to both the TV and the input source. If the cable is firmly connected and you're still seeing vertical stripes, the next thing to check is the settings on your TV.
Make sure that the resolution is set to 1080p and that the refresh rate is set to 60Hz. If you're still seeing vertical stripes, try changing the HDMI input that your TV is connected to.
If you're still seeing vertical stripes after trying all of the above, it's possible that there is a problem with your TV. You can try resetting the TV to see if that fixes the problem.
If the problem persists, you may need to contact customer support for further assistance.
Will replacing the T-con board help?
The short answer is: maybe.
The longer answer is that it depends on what is causing the problem in the first place. If the problem is with the T-con board, then replacing it may well fix the issue.
However, if the problem is with something else - like the LCD panel itself - then replacing the T-con board is not going to help.
Samsung 65 inch UN65NU6900FXZA Smart TV -No picture
Without getting all technical your LED backlights are bad, the part of unhooking one ribbon cable and not having the repeated cycle would be normal in this model set.
1helpful
Vertical Lines on Samsung TV
Test the voltage at the main to make sure you have the proper voltages from the power supply, if they look ok try a new timing board.
Which components might be bad in my Samsung LED UN65NU6900FXZA FA01 tv?
This can be caused by a loose connection on any of the cables to the display or it maybe a failed connection that is soldered at the edge of the display. If you take your thumb and apply pressure to the edge of the display all the way around in different spots and the line vanishes, it is the actual lcd edge.
What causes a Blue Vertical Stripe on left side
Can be the t con board or the lcd panel. its only possible to finalise by replacing the t con board. Before going for a new t con board try to check the connections from t con to lcd panel. if its possible remove and reconnect it. sometime bad contact can cause such problems. Also added a link which would be help full for you.
http://electro-medical.blogspot.in/2015/11/lcd-tv-t-con-board-troubleshooting.html
Vertical lines
You will most likely need to have the set diagnosed. Vertical lines can be the result of a defective t-con board, faulty lcd panel/t-con connections, or a faulty panel itself. Do the lines stay or do they come and go? Older Samsung sets are known for faulty LCD panels!
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
