Question about LG Washing Machines
Error code 44 - External air temperature thermistor on LG Inverter V model LSU121HSV3. Need diagram to identify which component is faulty
  • LG Master
  • 2,522 Answers
You posted your question under LG washing machines. Try reposting under air conditioner
Posted on Nov 24, 2019
6ya staff
SOURCE:
Chuck Clark
  • 33 Answers
SOURCE: error c7
You can reset the C7 code, hold down 0&8 power machine up. Then push 87 & print, change the number to 0 with number keys press interupt key, then press 0&9 @ the same time to exit. This should clear the C7. Let me know if you need more help.
Posted on Oct 27, 2007
Anonymous
  • 405 Answers
SOURCE: C4 error code on LG artcool airconditioner
www.yx2.fi/LG/wall_and_art_cool_error_codes_2007.pdf
Please read this article, I think it will help you solve your problem
Posted on Jan 14, 2009
Anonymous
  • 400 Answers
SOURCE: LG Inverter Air Conditioner showing CH 02 what can I do?
The model number would be on the right hand side of the outdoor unit and same on the indoor unit if it is a midwall split. If it is a flat cassette cieling type you may need to open the grill, which is simply two little levers either side of the grill, and the grill will swing open. Without the model number it is difficult to give accurate info. However, I can offer the following. One, check the condensate drain. You can just blow into the drain pipe from the outside and this sometimes clears clogged mud in the drainpan. Or two, error reading can also come from phase failure (in the case of a three phase unit) or power related problem. This can be solved by switching off the mains and then switching on again to reset. If you have a phase failure you would need an electrician to confirm that the power supply is good. Unless you have a volt meter.
Posted on Mar 04, 2009
Chris Perkins
  • 5 Answers
SOURCE: LG Tromm washer WM2688HWM tE error code. Very easy
LG Tromm Washing machine te error. The manual says to call for service. Not much help there. The reason for the error is the thermistor circuit (resistive element that becomes less resistive as it increases in temperature). The thermistor acts as a heat sensor. In many cases, the error occurs because the wireing harness is too tight at the bottom of the drum and one of the wires in this circuit becomes disconnected with all of the movement of the drum (unbalanced load, normal cylcing etc).
1. Unplug the washing machine from the wall. The thermistor circuit is at line voltage (110 in the U.S.) and it will bite! So do this first before proceeding.
2. Move the washer out so you can get access to the back of it.
3. Remove the stainless panel (the one that is not painted, it is large (aprox. 16x18 inches). It is held in place by 4 phillips screws.
4. Locate the thermistor connection block near the bottom of the machine, at the center of the wash drum. It is the small white connector that has two wires running to it. One wire is dark blue, the other is light blue. Insure that neither wire has pulled out of the connector. If either of them have, repair the connector and provide enough extra wire ( aprox. 2") to provide cable relief.
5. If the cable connector and wires are ok, there are other solutions here that recommend either cleaning or replacing the thermistor.
Good luck to you.
Posted on Aug 04, 2009
Anonymous
SOURCE: LG WM2277HW Thermistor (tE) issue
To be more specific, unplug unit. Behind the machine are two plastic kick plates, remove to slide off the top. Once off, two top self tap metal screws and one screw behind panel wall, remove. Remove two detergent screws. Lift electrical panel and set on top of machine. Remove four top screws. Bottom drain has one screw in front, take out plastic cover and one screw in back. Take off rubber by opening door. With a screw driver, prey and lift up the brass spring ring and remove. Then the front panel should slide up and out. Be careful because electric wire is still connected, move to the side of unit. You will then be able to find the thermostat. Unplug and replace, you will need to use the same rubber bushing. Took me an hour, I’m not an appliance repair guy.
Posted on Feb 09, 2010
LG washer front loader what should be the ohm reading test good or bad for the thermistor
A thermistor varies its resistance according to temperature. As long as it is not showing infinity or extremely low, we need to know what the make and model are.
Jan 19, 2017 | LG Washing Machines
Tip
Washing Machine Fault Codes These fault codes are written for washing machine...
These fault codes are written for washing machine repairers and not for the general public and they assume a certain level of competence on the part of the user in diagnostic routines. I have added some notes to try to assist you in determining the nature of the fault you have but, you will still need to investigate each failure on its own merits.
Please check that any washing machine spares recommended are suitable for use on your particular model and serial number. Please, don't guess or assume as spares can be altered on a production run with the same model number having several different alternative components used.
E1
Not filling in allocated time
This is essentially a fill timeout error which will normally mean that either the water isn't on or that an inlet valve has failed. We do list the generic water inlet valves for Samsung washing machines in this section and, if you're clever you can use one of those by altering the connections but, if you need the genuine one specific to your model please contact us.
E2
Pump won't empty - not draining
As usual with these error codes for not draining the first thing to do is check the pump filter. When replacing the drain pump there are two basic options, the genuine one from your manufacturer or the cheap version which is essentially the same pump.
Also see below about detergent use as it applies to drain errors as well as overfill error codes.
E3
Overflow - overfilling with water
This fault code tells you that the washing machine has detected an overfill situation and, usually, they will stop and drain for safety then report the error code above.
This error can be caused by poor quality detergent or overdosing detergent both leading to excessive foam. This foam traps air in the pressure sensor hose and falsifies the error of an overfill. If this is the case, if you leave the machine for an hour or so and try it again it should then be clear but, whatever you do when you try it again do not put more detergent in the machine.
If this solves it, adjust the detergent quantity or switch to a better quality detergent to prevent it happening again.
E4
Out Of Balance (OOB) detected
This is basically an imbalanced wash load detected that the machine has failed to sort out on its own and therefore couldn't spin to the full speed. Just sort the load and try it again.
E5
Water temp rising or falling too quickly
Normally an NTC temperature sensor or wiring to the sensor that's faulty.
E6
As above.
E7
Pressure switch
The error code is telling you that there is an error or fault somewhere in the pressure switch circuit, this could be the switch itself, the wiring or the main control module.
E8
Temp too high on low temp washes
Normally this will be the wash temperature thermistor or NTC that's faulty, please contact us if you need the thermistor with the model and serial number.
E9
Water leak, Water level has reduced
Basically this fault code means that the water level has dropped while the machine has been running so, it's either a leak, faulty pressure sensor, wiring, water escaping to the drain or the control PCB.
EA
Motor tacho generator error
Self explanatory fault code. Most manufacturers do not supply parts for their motors, only full motors and they can be model specific.
EB
Motor triac error
As above.
EC
Thermistor
A thermistor is a type of resistor whose resistance varies significantly with temperature, more so than in standard resistors. The word is a portmanteau of thermal and resistor. Thermistors are widely used as inrush current limiters, temperature sensors, self-resetting over-current protectors, and self-regulating heating elements.
Thermistors differ from resistance temperature detectors (RTD) in that the material used in a thermistor is generally a ceramic or polymer, while RTDs use pure metals. The temperature response is also different; RTDs are useful over larger temperature ranges, while thermistors typically achieve a higher precision within a limited temperature range [usually 90 °C to 130 °C].
As fault code E8
ED
Door Open
Close the door and restart the program!
If that doesn't cure the problem it will most likely mean that the door lock is faulty and there's two commonly used on Samsung washing machines, this one and this one
on Jun 20, 2011 | Washing Machines
What does the error message C8 mean?
press the helpful button
found this on fixya by J Mcallister
Heating roller warm-up error 2
?? The heating roller temperature does not reach the ready
temperature for 90 seconds after the heating lamp on.
?? The heating roller temperature does not reach 80°C for 13 seconds
after the IH inverter on.
?? Defective thermistor
?? Defective IH inverter
Related SC code: SC 542
1. Check if the heating roller thermistor.
Ricoh Aficio SP 100SU User Manual Error And Status Indicate On The Control...
Jan 27, 2016 | Ricoh SP 112SU 3in1 Laser Printer
LG Inverter V model LMN096HVT air conditioner multi unit has error code 9. How can I fix this myself?
  1. How to fix lg with code CH05 - Fixya
    www.fixya.com/support/t12722126-fix_lg_code_ch05May 8, 2012 - Question about LG Air Conditioners. 2 Answers ... Hi, i've just moved into a house with a LG ART COOL C24AWR N80 inverter unit in it. Have just .... LG Inverter V model LMN096HVT air conditioner multi unit has error code 9.
Jul 12, 2015 | LG LMN096HVT WaMounted Mini Split Indoor...
Ge front load error codes t01
make this test: God bless you
- 45 -
Service Test Mode
The dryer control has a service test mode that can be utilized by the service technician in order to test
critical components and to access error codes. This test mode will help the service technician to quickly
identify failed or improperly operating dryer components.
Test Mode Description
t01 Model ID Verifi
es (or sets on new board) the proper model id.
t02 Error Codes Lists up to 10 control-detected problems.
t03 Software ID
Displays the software version number and the non-
volatile memory version number.
t04 Program Non-volatile Memory Test Control computes and compares the 16-bit CRC of
the non-volatile memory with the pre-computed
version stored in the non-volatile memory.
t05 User Interface Control turns on all LEDs and the 7-segment display.
t06 Keys Continuity Verifi
es that all displays and buttons work.
t07 Outlet Thermistor Displays outlet thermistor temperature.
t08 Inlet Thermistor Displays inlet thermistor temperature.
t09 Moisture Sensor Displays voltage read from the moisture sensor.
t10 Exhaust Detection Verifi
es status of the exhaust system.
To enter the test mode: To exit the test mode:
Disconnect the power for 30 seconds.
Reconnect power and within 30 seconds of
reconnecting power:
Press signal button.
Press delay start button.
Press delay start button. (Displays t01)
1.
2.
a.
b.
c.
d.
Press the power button during the test selection
mode.
Note:
A dryer left in the test mode will exit the test
mode after a period of 30 minutes
Oct 01, 2013 | GE Dryers
TE code wm2688hnm
proceed with common sense and logically, fix it use the Vom or DVOM .God bless you
For this error code you need to check both the water heater or element and thermistor, basically the washing machine is reporting a fault on the heating circuit with this fault code but it is not capable of identifying exactly where the fault actually lies.
On non-display panel models this fault code is denoted by the lights for 95, 60, 40 and cold being lit or flashing.
  • Check water heating element
  • Check heater for contunuity,
  • Check steam heater for continuity usually
  • Check thermistor or temperature sensor
  • Check the thermistor resistance,
  • Check wiring to water heating element
  • Check connections to water heating element and temperature sensor
Aug 03, 2012 | LG WM2688HWM TROMM SteamWasher
LG WD 80260 NP washing service manual / circuit diagram
tE is heating error. Water not heating, Could be a faulty element, faulty wiring, faulty temperature sensor or faulty control board.
Jul 07, 2012 | LG Washing Machines
I have a LG Dishwasher model LDF6810 and it has an error code te...thermistor. Can I fix this?
Check the thermistor before you change it it can also be the PCB...
Check the temperature. (Test Mode) If the temperature is displayed, adjust the Inlet Water Temperature to 120 . If the temperature is not displayed, check the wiring connection. check the electric resistance of Thermistor. (11~14k at 77 ) Replace the PCB
Aug 29, 2009 | LG LDF6810ST Stainless Steel Built-in...
Washing Machines Logo
124 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
