Question about Toshiba Televison & Video
How do you get Toshiba fire TV edition 50" TV to connect and recognise bell satellite receiver?
Connected by coaxial cable
    Top Expert:
  • Toshiba Master
  • 10,627 Answers
Go into set up and select cable then channel search and use 3 or 4
Posted on Nov 23, 2019
6ya staff
SOURCE:
Anonymous
SOURCE: Coaxial to component
Get a VCR and use the VCR as a "bridge" between the cable input and the TV. Your TV should have generic RCA jacks that will accept the output from the VCR.
Posted on May 27, 2008
butch welch
  • 147 Answers
SOURCE: connecting VCR to TV
Oh man dont shoot your stuff instead use your remote and go to your menu and select your input. You tv is looking at your coaxial input but you can select which input you want. 1, 2 front back whatever you need. channell 3 or 4 has nothing to do with connecting up your dvd if you connect and choose the front connection in your menu.
Posted on Oct 21, 2008
Anonymous
  • 98 Answers
SOURCE: Samsung LN37A550P3F shadow image
It seems new TV.
But that kind of problem is related LCD panel.
If you can replace LCD inverter first.
then not working need to replce LCD panel.
Posted on Feb 09, 2009
Anonymous
SOURCE: no picture connecting laptop to LCD TV both Toshiba
Try the fn key and the monitor key (f4?)at the same time to activate external monitor
Posted on Feb 17, 2009
larry james
Larry Stiles
  • 301 Answers
SOURCE: I connected my STR-DG520 5.1 to my TV Toshiba
In your str-dg520 menu you have the option to have the sound routed to your tv or out your stereo system. select which one you want.
Posted on Jul 16, 2009
No coaxial connected to my wall plate
change wall plate connection must be busted
Feb 27, 2015 | Cables To Go Televison & Video
How to put coaxial cable in harman kardon
A coaxial cable is the name given to a digital cable that appears identical on its connectors to an RCA cable that is designed for analog signals; however their resistance measurements are different.
On the receiver you are asking about, the input and output terminals are labeled as coaxial and are colored orange. These are single cable connections. Power off the unit, and also turn off the device you want to connect the receiver to. If you are connecting a device such as a DVD, CD or Blu-ray player to the receiver, look closely at the cable sheath. You will see an arrow on it. That arrow must point at the RECEIVER coaxial INPUT if the other end of the cable is connected to one of the devices just mentioned. Make identical connections on each end pushing the pin all the way onto the terminal until it stops; coaxial connections are typically very tight. If it is too difficult to fit, putting a dab of contact grease or tuner cleaner onto the connector will help.
Feb 21, 2012 | Harman Kardon AVR 130 Receiver
Hi. I write from spain. I have the blu-ray LG
Have you tried the another optical cable? They don't tolerate dirty connections or small-radius bends in their routing. THAT (and the expense of optical cables) is why I always choose coaxial connections when possible.
Mar 02, 2011 | Yamaha RX-V363 Receiver
Cmment utuliser ce modem
  1. Save your work and shut down your PC.
  2. Connect the coaxial cable from the coaxial jack in your wall to the coaxial port on the rear of the modem. Turn the connector clockwise until the cable is firmly connected to the modem. Gently tug on it to make sure it is connected.
  3. Connect the appropriate cable, USB or Ethernet to the matching jack on the rear of the modem. Connect the other end of the cable to the appropriate port on your computer.
  4. Connect the modem's power adapter to a surge suppressor or a dependable wall socket.
  5. Press the power switch on the front of the modem to turn it on. Power up your PC. If you opted to use the USB connection method, you may have to install the appropriate drivers. Check your owner's manual for specifics.
  6. Launch your web browser http://192.xxx.xxx to verify Internet access.
Dec 04, 2010 | RCA Thomson Digital Cable Modem (DCM305R)
I want to connect to a TV that;s already connected to a cable tv box
What do you mean? Do you want to connect or add another tv to that cable box?
Like two TVs connected to one cable box. If so, on the back of the cable box you have three different ways to connect a tv from, through AV cable, component cables and coaxial cable.
If the main tv is connected by coaxial, the second tv can be connected thru AV or Component cables..
Hope this helps.
Sep 21, 2010 | Televison & Video
Connecting the cable coaxial cable to a P50HDM VIZIO TV
yea wtf same prob here just want to put a indoor antenna now I got to go buy an external receiver booooooo!
Jan 10, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Connecting TV to combo DVD and VCR
When you say "can't get the TV to play through the VCR", do you mean that you can't get the cable-stations to play through the VCR to the TV? I'll assume that's what you're trying to accomplish.
The most common way to connect a VCR to a TV is through a coaxial cable, from the port on the rear of the VCR labeled "Out to TV." There should be another coaxial port labeled "Cable/Ant In." This is where I picture your cable programming is currently connected.
Instead, it sounds like you connected the VCR to a modulator (probably thru RCA composite cables, which have yellow / red / white plugs). Then the modulator connects to the TV thru a coaxial cable. This will successfully play the VCR to whatever specific channel (perhaps 2, 3 or4), but the modulator doesn't know of any other signals to send to your TV.
2 possible solutions:
1) If the modulator has a coaxial port labeled "Cable/Ant In" or something indicating "In" at a threaded coaxial port, connect your cable-programming to this instead of the to the VCR.
Depending on what type of modulator it is, when you want to switch from watching the VCR to watching cable-programming, you might have to push a button on the modulator to make the swtich, or you might not. Your modulator might put the VCR on channel 3, and allow the higher cable channels to filter though to their respective stations. Most cable providers will leave channels 2, 3 and 4 blank for this purpose. Try it and see.
2) Axe the modulator. Take it out of the system entirely. Connect your cable programming to the VCR "Cable/Ant In" and use another coaxial cable to go from the VCR's "Out to TV" port to the TV. When you want to switch from watching the VCR to watching cable, press a button on your VCR or the VCR's remote. Usually this button is labled, "TV/VCR."
If this does not help, write back and explain in more detail how your system is currently connected.
--axoplasm
Nov 02, 2008 | Televison & Video
Need directions to install a dch70 box to tv
dear woolifer ,
I am not an expert but i hope i can help you..
is it youmean digital cablebox?
if it is try this-
This is a problem a lot of people have with coaxial-only televisions because DVD players do not have coaxial (RF) outputs, which means they can't be connected directly into a television with only a coaxial (RF) input. The solution is to purchase a RF modulator, which is a small device that will convert the AV output from the DVD player to coaxial (RF).
As for the instructions, I am going to assume the DVD player is not a combo unit with the VCR, and that you want to record TV on your VCR. Step 4 will include connecting your DVD player, but if the DVD player is a combo unit with the VCR, just ignore step 4 part as DVD connection will be included in the VCR set up. Actually, you wouldn't need the RF modulator if it is a VCD/DVD combo unit.
  1. Connect the coaxial cable coming out from the wall to your digital cable box in the ‘video in’ slot. It might also be labeled ‘antenna in’ or ‘cable in’.
  2. From the cable box, connect a coaxial or composite (yellow video cable) and stereo (red-white) RCA audio cables to the VIDEO IN terminal on your VCR.
  3. From the VCR, you will have to connect this to the RF Modulator using a coaxial cable from the VIDEO OUT on the VCR to one of the IN ports on your RF modulator.
  4. You can now connect your DVD player to the RF Modulator by using the yellow-red-white composite/RCA cables from the VIDEO OUT on the DVD player to another port on the RF modulator.
  5. From the RF modulator, connect this unit to your TV by using a coaxial cable. It will be from the VIDEO OUT on the RF modulator to the VIDEO IN or CABLE or ANTENNA IN port on your television.
This should be all you need to get started watching your digital television. In simple terms here is what you did:
Coaxial from wall to cable box
Cable box to VCR
VCR to RF modulator
DVD player to RF Modulator
RF modulator to TV
You will only be able to record what is on channel
Apr 09, 2008 | Computers & Internet
PCM 2.0
I had the same problem with my 321 system. The fix is in the cable box settings. You want to change the Digital Out on the cable box..my choices were HDMI....Dolby Digital..and None. Choose Dolby Digital and it will show up on your Bose 321 display. I also have my cable box connected to my bose system via optical digital cable...and a digital coaxel cable from my dvr to my bose. Change that output setting on my cable box took care of the PCM 2.0 problem for me.
Dec 19, 2007 | Audio Players & Recorders
Televison & Video Logo
22 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
