Question about LG Cell Phones
Lg cj 88 no sound even if volume is at max any prcedure to reset factory settings
  • Max Miller
    Max Miller Dec 02, 2019
    yes it very easy to get factory reset. its easy way go to setting and select the factory reset . Even do you have any issue in Quickbooks . Dial number of expert Quickbooks enterprise support
    Problem Solver:
  • 12 Answers
If you want to do a Factory Reset :
1. Shut Down your phone
2. Hold Volume + and Power Button at the same time for 10 Seconds
3. wait for the android logo to come up
4. select the Factory Reset
Posted on Dec 02, 2019
6ya staff
SOURCE:
Anonymous
  • 9 Answers
SOURCE: lg television du-27fb32c reset to factory settings
mute on the remote and menu on tv
service mode and go to factory reset
Posted on Dec 17, 2007
Anonymous
SOURCE: No Sound on my Tomtom one 3rd edition GPS
I did a hard reset (hit the reset button on the bottom with the power on) and the sound was restored when I powered it up. No settings or favorites were lost.
Posted on Dec 05, 2008
Anonymous
  • 5 Answers
SOURCE: Volume is too low, even then it is turn up to the max.
Have you looked at the menu on your cable or satellite box to see if there is a seperate volume control for the box?
Usually it is found under
Settings>>Audio>>STB Volume
Posted on Apr 10, 2009
Anonymous
SOURCE: Reset to factory settings
have you tried the companies website? Beltronics lists models going back 4/5 yrs!
Posted on May 05, 2009
lightshock20
SOURCE: Sound volume is very low on incoming calls. Have
Send your phone to service, my nokia is dead too, so far 6 friends that have NOKIA TOUCH mobiles 5230, 5530 and 5800 all of them lasted around 6-8 months before the sound from incoming calls is very low with all the settings on volume set on high.
Things that will NOT fix the problem: Reseting phone, isntall up to date software.
BEST SOLUTION GET YOUR PHONE TO SERVICE
Posted on Nov 29, 2010
LG flip phone won't ring, set on vibrate/ring and volume all the way up
My LG flip phone volume is all the way up. I've tried star key pound key volume keys even tried it during playing sounds and no luck. It has keypad volume but no ringtone or sound volume whatsoever. I've reset my phone and also dialed *228 but no luck yet. Any ideas?
Jan 29, 2017 | LG Cell Phones
How do you hard boot into recovery mode,volume down and power then release both and press again on lg screan dont do it both ways only factory reset
Do not forget to backup your phone’s data before doing a factory data reset. Here’s our guide.
Performing a Factory data reset restores your device to the original factory settings as it comes out of the box. It also deletes the data like installed apps, contacts, messages, images, etc. present on the internal storage. It does not, however, affect any data stored on the external SD card. Now here is how you can hard reset your LG G2/G3 from device Settings:
Tap the Menu key from Homescreen.
Select System settings> General.
Now scroll to PERSONAL.
Select Backup & reset option.
Tap Factory data reset> Reset phone.
Select Erase everything.
When the warning window prompts, tap OK.
Hard Reset LG G2 with Hardware Keys
If you unable to perform a factory data reset on your LG G2/G3 using the device settings for some reasons, you can try the hardware key method. Just follow the steps given below:
Turn off your LG G2/G3.
Now press and hold the Power + Volume down buttons simultaneously for about 8 seconds.
When the LG Logo appears, release and then immediately re-hold the Power button.
Release the Power key as soon as you see the ‘FACTORY HARD RESET’ screen.
Press the Power key to reset your device.
Press the Power key again to confirm factory data reset.
Wait till reset is done.
Boot LG G3 /G2 into Safe Mode
To fix an issue caused by a 3rd-party app, you can boot your LG G3/G2 into Safe mode and delete the suspect app. You can turn on Safe mode by following these steps:
Jan 06, 2016 | LG Cell Phones
I don't have sound even if the volume is max
Have you entered to Setting-Sound to check.
If so, and if that does not work, try with headphones.
If still does not work, try Setting-Reset to factory (you will losse everything so backup it)
If does not work... the unit is damaged
Feb 16, 2015 | Proscan 7-Inch Android Internet Tablet,...
Need to hard reset my LG.l34c Mobil phone
To hard reset your LG I34c mobile phone, follow below instructions.
Note: Back up all your important and personal data before factory restore. Factory restore will erase all your data and restore device to its original manufacturer settings.
1. Turn the phone off, hold the Home and Volume Down button and then press and hold the Power button too until the device turns on.
2. You will get wipe data / factory reset option
3. With VOLUME buttons select wipe data / factory reset
4. Confirm with Menu key.
GuruAid.com
Dec 19, 2014 | Cell Phones
I don't know how to reset my lgp999dw
With phone shut off, press and hold the volume down button and then briefly press the power button.
When the Android image appears, release the volume down button.
press volume down to clear storage and volume up to factory reset.
Nov 09, 2014 | LG Cell Phones
Volume really low, even when turned right up
So the speakers and the individual amp channels work so that lets out the obvious big hardware items.
This is starting to sound like an obscure setting was set or changed by mistake.
It would be nice to figure out what that is/was in case it happens again but you may eventually have to resort to resetting the receiver to factory defaults and start over by holding the1/0 button for 5 seconds.
Mar 04, 2010 | Sony STR-DE875 Receiver
I am having to turn up my volume control to max in order to here any sound. Is the volume going out and what is solution?
I'd unplug and give set a reset for a few minuets then try again.
I've seen cable boxes great this problem where people think its the TV. check this by trying to play a DVD movie on your TV and test sound there,.
Jan 04, 2010 | LG 42LC2D 42 in. LCD HDTV
Sound too low
The speaker could have gone bad. Or it simply could be corrupted settings for your saved user settings. To reset your V995 to the factory default settins:
-- Power off your V995 using its power button.
-- Hold down the two "Program" buttons and, while holding down these two buttons, press the Power button. Release all three buttons when "Reset" is displayed on your V995's display. Performing this factory reset forces the V995 to load the factory default settings which are permanently stored in a separate part of the firmware code. These settings then overwrite your stored preferences which are stored in another part of the memory. Now, all you have to do after performing this "factory reset" procedure is to once again set all settings to whatever you prefer.
Dec 18, 2008 | Vector 995 Radar Detector
Volume using remotes either ramps to max or all the way down
Go into the service menu and reset the main board.
Jun 26, 2008 | LG 37LC2D Television
Cell Phones Logo
131 people viewed this question
Top LG Cell Phones Experts
William Norris
William Norris
Sheldon Dedek
sheva420
sheva420
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
