Computers & Internet Logo
b
berkis kusasi Posted on Nov 23, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My sony hifi component MCHGZR880 is displaying mech error on lcd monitor w/standby mode only
Leroy Elliott
Level 3:
Fixya-Fanatic:
Visited the website for 90 consecutive days.
  • Master 425 Answers
  • Posted on Nov 23, 2019
Leroy Elliott
Master
Level 3:
Fixya-Fanatic:
Answers
425
Questions
0
Helped
137166
Points
1154
Check the cooling fan in the rear
5 Related Answers
Anonymous
  • 109 Answers
  • Posted on Jan 25, 2008
SOURCE: sony kdl 32 inch lcd tv (apprx 2.5 yrs old)
Usually resetting a device like that is done via it's On Screen Display (OSD). Maybe you need to contact Sony Tech support.
You can do this by clicking the below link:
[Sony Tech. Support]
Let me know if they have a solution to your problem.
Greetings,
DarkNeogen
Anonymous
  • 4889 Answers
  • Posted on Aug 30, 2008
SOURCE: Compaq 1501 15" LCD Monitor ( Blinking Display)
Hi BOY! :P
Check if there is anything wrong with the video input cable to the monitor. If not then you should move ahead with the replacement of the ceramic fuses. There should be around 6 of them in most monitors i have fixed. They will look like this(click here) They should cost you around 1$ each.
If none of these work then your monitor's inverter board is probably screwed and needs to be replaced. should cost you around 30-60$.
Anonymous
  • 47 Answers
  • Posted on Aug 30, 2009
SOURCE: Monitor stuck in standby
Try tapping F8 when booting and then choose 'safe mode with networking'
if this works go to the lcd manufactures web site and look for a specific driver for your screen.
Anonymous
  • Posted on Oct 08, 2009
SOURCE: Dell SE198WFP 19" LCD won't come out of standby
I went into the BIOS (with F2 during restart) and changed a value -- IIRC it was called something like "power management scheme" -- from the default S3 to the other choice, S1. Now the old Dell XP Dimension 2350 will go into and out of Standby correctly and the new SE198WFP 19" LCD will too.
Anonymous
  • Posted on Jun 06, 2010
SOURCE: philips 17 inch 170s4fg lcd monitor,display flickering
I have Got one philips 170S lcd monitor. Iam having flicker peoblem and my display not stable. pls, give me ur best solution for the above problems.
MY SONY HCD GN1000D IF I SWITCH ON THE POWER IT IS AUTOMATIC OFF ,AND BACK TO STANDBY MODE
Sir
this problem indicate two type of problems
1=when cassette mechanism stuck then display appear Eject and set turn off
2 if the out put short then set like this behavior please check if the mech error then service the mechanism and change belts otherwise replace amp ics one by one
thanks
m Nasir
Hello can u help me about my MHC-gzx55d sony hifi component, when you turn on the power, the screen display appear "PROTECT" what is the problem and what is the possible damage of my component. please help...
When it goes into protect mode it has been over loaded. Remove everything from the component and unplug the unit for a minute or two. plug it back in and see if it pops out of protect mode. If this does not work then you will need to do a factory reset or check the fuses on the inside of the unit.
Sony kdl-32ex500 error codes
B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
Dell backlight indicators
A computer monitor has a front-mounted LED that displays its current status and flashes in the event of an error. When an error occurs, the flashing may be accompanied by an error message on the screen. If the screen does not display an error message, the problem most likely falls into one of four common categories.
Unsupported Display Mode A video card has the ability to send output to the monitor at many display resolutions and refresh rates. However, no single monitor is capable of supporting every possible display mode. When the video card sends an unsupported display mode to the monitor, the monitor shuts off to prevent damage and blinks, or displays an error message. Standby Mode b> When a monitor detects no video signal from the computer, it assumes that you have turned the computer off and enters standby mode to reduce power consumption. Dell and HP monitors display an amber light when in standby mode. The status light on an Apple monitor blinks slowly. Incorrect Power Supply Some monitors such as certain Apple Cinema and Studio displays use external power adapters. Because different power adapters may have similar connectors, these monitors are designed to detect when an incorrect power supply is connected and blink the status LED rather than attempting to turn on. In the case of an Apple display, the LED blinks in an alternating short and long pattern. b> Backlight Failure b> A flat panel LCD display has an LED or fluorescent backlight that illuminates the pixels and makes it possible to see the contents of the screen. If the backlight fails and requires replacement, the monitor is unable to display any information. In some cases, you may be able to resolve this issue by turning the monitor and computer off, disconnecting and reseating all cables. If the monitor still has a backlight issue, it requires professional service.
The complaint for this DELL E152Fpb LCD Monitor was when switched on has power (LED lit) but no display ti goes yellow on the power led but it brings no display on the screen.
It is standby mode, no signal, It is possible that your computer is not POSTing.
Connect your screen to another computer/laptop, just to make sure, which component is not working. Either the Screen or the Computer.
Make sure the DVI/VGA cable is firmly connected as well as RAM modules and Graphics Card.
Please take the time to rate my expertise.
Thanks
HP monitor w1907 lcd switches off to standby.
your hp monitor has an electronic component problem inside, probably some busted capacitors or ccfl lamps that failed to light...best is to bring the unit to a qualified LCD repair center near you..
2answers
Full screen fluctuation in Acer Laptop.
Sound very much like your LCD inverter might be going luckily there pretty cheap and you should be able to find one on Ebay.
An LCD (liquid-crystal display) inverter is a component in laptop computers that supplies the power to provide a backlight to the monitor, enabling the user to view what's on the screen. This component is commonly the culprit when the monitor goes out and can be moderately simple to replace.
My sony kdl-42v4100 its turning off every 10 to 15 secns and the tv is going to standby mode.. how i can
I have a Sony Bravia KDL 40S 2000 (lcd tv - mfg 06') The power goes into standby which I know could be several things but my question is this....I'm into the set only $100 so far. Is there some pointers you can tell me to look for with the once I remove the case for a visual look see? I don't want to invest another $100 to find out it's a $400 fix....any info would be great b4 I chuck it. (FYI-I am mech. inclined so I wont use info like an idiot.) Thx - Dan Rathburn
Sony kdl 32 inch lcd tv (apprx 2.5 yrs old)
Greetings,
DarkNeogen
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
