Question about Samsung Televison & Video
JVC LT-32C690 SmartTV got the Sky picture and can change channels but it has no sound?
Replaced a Samsung TV in the bedroom that used a magic eye off the sky box in the lounge - new TV JVC LT-32C690 Smart TV - have got the Sky picture and can change channels but it has no sound? The sound on the TV is fine as it works directly on Netflix
    Top Expert:
  • Samsung Master
  • 10,627 Answers
Try changing input or source if ok try audio settings
Posted on Dec 07, 2019
6ya staff
SOURCE:
Anonymous
SOURCE: sky+ remote code for firstline (hisense?) tv42fs42pro1
jhj
Posted on Jul 10, 2008
Anonymous
  • 148 Answers
SOURCE: Sharp Notevision XR-1S projector
First off, Sorry for not getting back to you sooner. SHORT ANSWER: you need to run a second separate line for audio from the DVD Recorder to the projector, you will need this cable: . http://www.amazon.com/Stereo-Audio-Cables-Oxygen-Free-25FT/dp/B000UZC35K/ref=pd_bbs_sr_9?ie=UTF8&s=musical-instruments&qid=1224067234&sr=8-9 . LONG ANSWER:-with clarification request-- I need to know which Sharp Notevision XR-1S you have, a google search returned two devices of the same model number, one being a very expensive DLP and the other being fairly affordable. The cheaper of the two is about the price of an iPod where the DLP version is the price of a Laptop. It would seem you cant connect your "Sky Magic Eye" device directly to the projector as that would require the projector to have what's called an 'RF Demodulator' which it doesn't. That is why someone told you to get the DVD recorder, as it contains a tuner.  You got the picture from the magic eye, according to your question, so your on the right track.  What I need to know to completely answer your question is what is the connection from your dvd recorder to the projector. I am going to guess that you have not hooked up the audio output f the recorder to the audio input of the projector. SKY is only available in the UK and not the USA where I live and we do not have anything as wonderfully easy as SCART connectors, I wish we did, my life would be easier. When you don't use SCART you need to run a SECOND line for audio. The audio line is typically two RCA connectors on either end of a cable 1 meter to 10 meters in length. The connectors are white and red in color. If the Amazon.com link didnt work just search for "rca cable" and get the cheapest one that is the correct length.  CHEERS.
Posted on Oct 15, 2008
Anonymous
  • 178 Answers
SOURCE: I have 3 digital tv's one in the lounge/bedroom
Loosing digital channels is equivlent to a snowy analog channel, check you cable connections, and splitters to the tv, since you have two of them out, it does not make sense that it is your tv. It is a conneciton in your cable line somewhere.
Posted on Sep 02, 2009
Mick
  • 325 Answers
SOURCE: sky magic eye not working on hd
I work for Sky as an Engineer.
on your Sky HD remote:
service,
4,
0 1 select
make sure the power is turned ON
now go to the room you can not change the sky channels over with.
you should notice on the magic eye itself should now have a Red led light on it now. you should now be able to change the channel over just remember to press the blue sky button on the remote at the top otherwise this will not operate the sky box.
If not unplug this magic eye and try this directly into RF out 2 to make sure that its not the magic eye that is at fault. If it is working correctly then the light will appear.
Hope this helps
Little dish fitter
Mick
  • 325 Answers
SOURCE: Stopped receiving sky on second tv - does my samsung need a reset
I install a lot of magic eyes etc.
You have checked that the magic eye lights up when it is connected directly into the sky box. So your eye is working correctly.
the next step I would take is with your sky remote in your main room. press SERVICES, 4, 0,1, SELECT go to RF settings and check the rf channel and make sure the power is on. Take a mental note of the channel number.
Now go into the room where the link is feeding. Turn on the TV and go to channel number 6 press your MENU button and then go down to setup. go across to manual install and then down to the channel number type in what you retrieved from you box ie rf channel and then type it in and STORE.
If you go into your main room and just put the normal tv guide on ie blue screen. then check that your getting the sky into the other room. IF you are then great it just needed tuning in. IF not I would remake the coax connectors. as there may be a bit of copper braid touching the centre core. once this is done your sky should be on all you need to do now is put the eye back on. Once you have done this the red light should appear on your magic eye. if not go to your main box and follow the first instructions I gave you and turn the power off on the RF and then save and then go back in and turn it back on and save.
Hope this sorts out your problem
Cheers
Little Dish Fitter
Posted on Sep 17, 2009
Hi my Son has upgraded his old tv in bedroom to a Bush smart tv model no DLED32287HDCNTDFVP. I installed the channels first time. I have freeview channels except I cannot get the Sky channel to show?
When you say you have freeview channels, and then say you cannot get Sky channels this is not enough information that you have provided, but
I presuming in addition to freeview channels you also have a Sky Satalite receiver which is no longer connected to your Tv or your sons tv Either way Sky satalite have 2/4 lines which means you can have four viewings providing multi rooms is bought from sky, and additional boxes are fitted.
Or you can have 1 sky box main Tv and no the spare cable feed at the back of the sky box you can feed another cable to another tv from that same box but it will be same channels But you can now change channels using magic eye receivers etc, in any room.
But the question I believe is you had freeview but no long can receive sky channels the information is a little vague but hopefully I have helped a little
Sep 05, 2017 | Bush Televison & Video
I'm unable to get sky channels on my new Bush tv in my bedroom, It is connected by a magic eye,model:DLED32265HDDVDW,product:10103644.
hi make sure the RF 2 signal is turned on at the sky box, the light should be lit on the eye when the cable is connected,thanks
shaun
Feb 11, 2017 | Bush Televison & Video
TV link not working with my LG 50PH660V 50-inch Widescreen 1080p Full HD 3D Smart Plasma TV with Freeview HD/600Hz. I connected coax cable to my Sky Box, switching on the RF on, but I can not get it w
Hi Jim, your nearly there, all you need to do is go into the tv menu and move from DTV to the old type channel numbers and then find the bit where you can manually tune the tv to channel 68.
Have a sky menu picture running and you will see it come in.
Feb 03, 2015 | LG Televison & Video
I have a sky hd+ box in my lounge and wish to make the sky work in my bedroom, I am happy to only watch what is on the lounge tv in the bedroom (not have multi room) thanks Nigel
Run a coax cable from the sky hd+ box at the rear from the RF2 coax port, and into tv in bedroom.
If you want to change channels, buy a magic eye from eBay for a couple pounds, enter sky settings, and turn power on to the RF2 output. this will supply your coax to bedroom with 9v which will power your magic rye
Oct 23, 2013 | Neet Cooler Trunk Organizer
Virgin tvvo box
Not sure about about the transmitter but the magic eye thing is possible however you wouldn't be able to change channel unless your pointing your remote at your box because a sky box has power going through the magic eye but a virgin box doesn't
Jun 06, 2013 | Televison & Video
Help please purchase samsung smart tv ue37es6300 led hd tv connected it with magic eye to sky box in another room and picture is terrible much worse than tv we used before. Samsung say it is because it is...
Analog resolution is very low compared to what is possible on new HDTVs. Think of it as trying to spread a wallet sized picture out to the size of a billboard. You will see all the imperfections in the picture. The magic eye is not capable of sending a higher resolution picture. You need a different device to send the high resolution video.
Sep 24, 2017 | Televison & Video
Sky wired up by a basic splitter in loft want to use red eye.
Your vocabulary is not helping I will make some assumptions.
1 you have an antenna setup and want to have three tvs use it.
2 I don't know what sky is so I am going to ignore it.
from the antenna you will run a short length of rfcoaxial to a splitter\booster witch is powered this will allow you to split the signal to 4 or two or three tvs your choice. all tvs will need coax or rf cable run to them and btw 300 ohm cable is not called rf
coaxial cable is preferred because of its signal insulating properties and its longer life expectancy and all tvs today have coaxial inputs on them not 300 ohm.
Jan 19, 2010 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Cheers
Little Dish Fitter
Feb 27, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
Ekse
