Question about Toshiba Televison & Video
I have a Toshiba 43u6863DB smart Tv which is just over a year old and I am having problems controlling the sound level.
Recently whilst watching the tv and without having touched the remote control, a vertical sound level icon the full screen height appeared on the right hand side of the screen The tv has an optical cable connected for audio output to a home cinema sound system and the tv internal speakers were set to zero volume level.I am unable to delete this icon, I first tried the 'exit' and 'back' buttons and then all the remaining buttons on the remote without success. In addition the sound, now coming from the internal speakers, moves independently between the extreme high and low volume positions, alternately cycling between the highest and lowest levels If I try to change the volume level with the remote the tv automatically resets the level back to the previous highest or lowest level. I have tried to alter the tv system and audio settings using the remote to change the tv menu internal settings but I cannot turn off the internal speakers or set their level back to zero. It almost seems as if a virus has taken over the sound level controls for the internal speakers and is resisting any attempt to reset the internal speakers hack to a zero level but after looking elsewhere on line I have read that it is not possible for a smart tv to be affected by a virus. I would appreciate any suggestions as to possible causes and remedies for the audio problems I am having with the TV.
    Top Expert:
  • Toshiba Master
  • 55,370 Answers
Your TV has developed a circuit defect.
Posted on Nov 26, 2019
6ya staff
SOURCE:
Justin Smith
  • 135 Answers
SOURCE: Sound level unstable
Hi there!
You may have a button stuck either on the remote or on the TV itself. If this does not solve the problem, you may have to refer to a service technician. The IF Amp or the sound stage may be at fault. Good Luck, Regards, JUS004
Posted on Mar 25, 2008
Anonymous
SOURCE: Sony BRAVIA volume problem
I had this same issue, and solved it by putting the TV in "Theater Mode', which can be acheived by hitting the "Theater" button on the remote.
Posted on May 30, 2010
Azrael SRL
  • 11800 Answers
SOURCE: Complete loss of audio; video
In that case the internal audio amplifier has failed - most likely the power IC has died, it happens. All you need to do is to locate it - follow the speaker wires to the board, next to where they plug in you will find an IC with a radiator = unsolder it from the board then go to a hobby/electronics shot (or search for an replacement online) and get an identical one, solder it back and attach it to the radiator. That is all.
Posted on Sep 14, 2010
gopakumarg43
  • 76204 Answers
SOURCE: My Aiwa Colour TV, model No. TV-A2019, has
You just come aroung the sound decoder section of your tv. Decoder problems may cause the fult you pointed out. Since all the controls are electronically controlled, and all are through sound decoder, which converts sound to stereo the problem must be there. Since sound comes from two channels are ok, there is no problem around sound output. Check for some soldering loose contact, wire socket loose cotanct also.
Posted on Oct 15, 2010
Roberto Fabela
  • 85 Answers
SOURCE: I have an LG TV
There are two things that I can suggest.
1-Test your optical cables to make sure they a good on a known working source because they are very fragile and break very easily.
2-Try to eliminate the use of optical output from tv to receiver. There may be a problem from the HDMI to optical conversion at the tv. Instead, try running the audio directly from the source to the receiver, and let the tv deal with video input only.
Hope this helps,
Good Luck.
Posted on Jan 07, 2011
Why doesn't my tv power up?
Sounds like a power supply level problem. If the tv is more than 10 years old the PSU section should be re-capacitored if it has electrolytics.
Jan 13, 2016 | Toshiba Televison & Video
How do I connect the Home Theatre System so that I can hear surround sound from the TV instead of through the TV speakers?
watch this ......copy the below item and paste it on google ....there it will show you the whole video...it will solv your problem
Nov 20, 2015 | Sony DAV-SR2 System
What do I have to do to repair my Toshiba smart LED TV
Hiu Annick,
The cause of this problem lies in the power supply board of your TV. Most probably the main dc filter capacitor, the thickest one on the whole board, 150mf/450v should be defective. If you open the back cover and check, you may find this capacitor swollen up at the top. Apart from this you may find some other small capacitors also gone bad.
Another thing, please never leave your TV in stand by mode for long hours, specially when you are not home. Any power fluctuation during this period can harm your set.
A word of caution, please be very careful if you want to do it yourself, because your set is a big one and any wrong move can damage the panel.
I hope this helps.
Good Luck.
Aug 25, 2015 | Toshiba Televison & Video
Have a Luxor tv for less than a year, but can't find my receipt to take it back. I can use the remote easily whilst watching tv but once I turn into DVD it will let me go to the homescreen, but none o
Try re-programming the control or get a new one it may be that the control you currently have has de-programmed or is not properly cleaned
Feb 23, 2013 | Televison & Video
Toshiba Regza 32HL67 after about an hour the screen goes to black. I still have sound. I turn off and on the TV and picture comes back. This happened recently once before.... the difference between now and...
Your TV is 10 years old. There is no lamp to replace. There is a board inside the TV that controls the back light. It's called the ballast board. TV Parts Universal TV Stands DLP Chips ShopJimmy You might be able to get one here.
Aug 16, 2017 | Toshiba Televison & Video
Teco 32" flat screen whilst watching my tv the
I would love to help you.
Please respond by PRESSING REPLY OR COMMENT
Did you experience any storms recently? IE. the power cut off unexpectedly?
Bruce
Jan 13, 2011 | Sanyo 42 in. LCD TV
I have a panosonic surround sound system and a toshiba 60" tv and when watching tv speakers have a humming sound , but when watching a dvd speakers are fine and no humming sound.what is the problem? Tv...
it depends on what volume level the tv is on
if the level of volume is low and making the sound then try unpluging or pluging in the sound system to the tv
Sep 13, 2009 | Televison & Video
No picture on my Toshiba 42HP66 plasma tv.
I too have this problem with no help from hh Gregg, where I bought the tv, and no help from Toshiba. I resorted to calling the BBB and complaining about the defective workmanship. I took the tv, which is less than 2 years old, apart and found the y-sus board, behind the y-sus board is a foam rubber spacer to seperate the circut board from the backside of the screen. I think this pad is designed to prevent heat buildup in the y-sus board. The pad itself is held on by glue and that glue melted causing the y-sus board to short out. I noticed this after finding a tacky substance behind the board. The heat from the plasma screen melted this and also the pad itself. Toshiba claims no resposibility because the tv was out of warranty. Thanks Toshiba.
Jan 22, 2009 | Televison & Video
Smelly television
You probably have a deceased rodent, who got in there and electrocuted himself. Really, I'm not joking
Jun 29, 2008 | Televison & Video
Televison & Video Logo
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
