Hi Lou-
I found this other link regarding CTV Go not working on Samsung TV. It may not solve the problem you're having but will give you some more information about the problem.
https://www.reddit.com/r/canadacordcutters/comments/bd0s06/ctv_go_not_working_on_samsung_smart_tv/
Hope this helps.
Hi Lou-
I found this link.
https://www.google.com/search?q=How+do+I+get+the+CTV+app+on+my+smart+TV%3F&sa=X&ved=2ahUKEwi_qMzw04jmAhUpFTQIHd1fA5AQzmd6BAgLEBY&biw=921&bih=463
Go down to "How do I download CTV app on my smart TV?"
Hope this helps.
Testimonial: "Thanks but I tried this before but it does not have the CTV apps."
SOURCE: taken delivery of 40" samsung
Make sure you have it set to wireless off in the menu or it will not recognise the ethernet port on the back even if it is flashing. Most tvs with browsers come with the wirless function set to on. Also if it has search for internet signal you could try this to get it to rec. as well.
SOURCE: No Facebook app on optica smart tv
What is the exact model number to your TV? Look for this detail, at its back cover. Gopakumar Gopalan Google
Testimonial: "Model no 7042. That's all it says. Sku is t844 not sure what that is thought I'd put it on here incase any good. Have you an idea what to do?"
SOURCE: Visio smart tv apps
You have to jailbreak it and if it's android I can install the app store
SOURCE: How to Add Apps to a Smart TV?
1. Verify that your Samsung Smart TV is connected to the
Internet using a wireless or wired connection. ...
2. Power on your television and select "Smart Hub" from
the main menu.
3. Select "Apps," then scroll to and select "Samsung Apps"
using your remote control.
None that is available right now.
