SOURCE: HOOVER STEAM VAC SPIN SCRUB
Cannot hook the upholstery cleaner into slot..lost manual in fire
SOURCE: burning smell and loud noise from hoover steamvac
Perform general maintenance - cleaning filters,etc. If it still exists, take it apart and check the motor... If the motor is sooty on the copper coils inside, then it's had it's day. You could try and buy a replacement motor, but typically, its cheaper just to get a new hoover.
SOURCE: Hoover H3030-006 240 V Motor making
If you have little to no suction, that sound is happening because you most likely have a clog some were in the vacuum.
smell is probably your motor over working itself do to the clog.
also double check your belts on your brushes that they are moving with the motor. smell and sound could come from the brushes being jammed which would cause the belt to freeze and heat up and could burn the belt and or your motor.
if it is still running though your not in the red yetm so triple check that the machine is cleared off all clogs and jams in the belts and brushes.
SOURCE: Hoover Dimension has no suction and it smells of something burning
pets in house? check all hose passages for "hairball" clog...and check the drivebelt that spins the brush...(some have an electric motor to spin the brush, thus no belt)
SOURCE: How do I hook up the upholstery attachment on a Hoover Spin Scrub 50?
To connect the upholstery tool, first remove the clean water tank by pressing down on the handle and pulling the tank forward. Remove the hose from the storage rack. Press down on the handle release lever and lower the handle to the ground. Unlatch the back part of dirty water tank and remove the lid. Pull the dirty water tank's front panel up about an inch and rotate the panel to parallel with the floor. Replace the panel with the converter and slide it halfway down until it is firmly in place. Pull the collar on the connecting tube towards the tube so that the black tabs are fully extended. Open the door on the hood labeled Stair/Upholstery cleaning connection and press the round solution tube onto the round projection. Press the collar firmly to ensure that the tube is connected. Replace the tank in a hinge-like manner and place the lid under the tabs on the front of the tank. Rotate the lid down onto the tank.
Now slide the upholstery tool on the connector of the hose until the tab locks into place.
The manual for the Spin Scrub 50 is available on the Hoover product page: http://hoover.com/products/details/fh50044/steamvac-spin-scrub-50-carpet-washer-with-tools/ . The direct link to the manual is http://hoover.com/file/1195/ . The directions are on page 14-15.
I hope this helps.
