Question about Frigidaire Refrigerators
I have a frigidaire refrigerator and I was mopping and bucket spill under and whole fridge went out I unplugged and nothing after 3 hrs I'm lost
    Top Expert:
  • Frigidaire Master
  • 55,370 Answers
The bucket contents shorted wiring in the bottom of the refrigerator.
Posted on Nov 27, 2019
6ya staff
SOURCE:
Anonymous
  • 92 Answers
SOURCE: my freezer section of an LG frech door is not getting cold enough.
you would have to take the back wall of the freezer of (after it has been running a while) see how much of the evaporator is frosted up if none freon leak or bad compressor if just a little on top then a restriction. if you open it and the whole top above the evap is a huge chunk of ice i would try a dryer filter(its part of the sealed system)
Posted on Feb 10, 2008
Dan Favata
  • 233 Answers
SOURCE: frigidaire self defrost freezer is puddling water
kind of a pain to get to, but there is a cover on both the front and back of the fridge, if you remove one (or both) you will see a hose that goes to the pan that all of the components sit in, you will have to get pressure to it from the bottom side. I suggest a "gallow gun" available at your local home improvement store, you may also be able to use compressed air in a can from a computer store
Posted on Jul 12, 2009
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: The Refrigerator is 2 years old, and is no longer
Hi Chris,
The problem would seem to be that you developed a small leak in the refrigeration system. This is also assuming that you checked and cleaned the condenser coils which are underneath the fridge. Excessive dirt could also cause this, but from what you are describing I would say the problem is more then that and you have a leak...
The only other thing would be thermostat sensor issues, but then the compressor would be cycling and not running steady...
heatman101
Posted on May 18, 2011
DAVID ALAN GRAY
  • 139 Answers
SOURCE: Can you please assist with
Well sounds like bad motherboard. Ihope you have some coverage on it. I hope this helps
Posted on Sep 08, 2011
TheMobilian
Dan Webster
  • 8220 Answers
SOURCE: CSX22GRZAWW freezer works, refrigerator warm
Damper problem.
This ice box has a damper which is controlled by a thermostat. When the fresh side be warm that damper opens and allows cold air to enter the fresh food section. It must be gone out. it is what i would check.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jun 12, 2012
Please help ..my fridge is swelling on inside back wall where my shelves are protruding can anyone help please its a beko xx
Sounds like you have moisture in there and it's freezing causing swelling. Sounds like you need to defrost- really defrost your fridge.
Remove the food to somewhere else, FIRST unplug the thing, open the doors and use fans to blow air in there to melt any ice in the unit.
Be prepared to mop up lots of water.from the floor and keep emptying your pan under the fridge if it has one. This can take a whole day to get done and maybe a day and a night.
Oct 15, 2015 | Beko Refrigerators
Repairman made service call and checked out the frigidaire. Said everything was ok except there was a leak in the inside water filter housing unit, so he went ahead and bypassed the filter since we have...
The filter under the sink should have nothing to do with the water supply to the icemaker. The "repairman" probably cut off the icemaker water supply by "bypassing" the filter.
Jan 08, 2014 | Frigidaire FGHB2844L (27.8 cu. ft.) French...
My FRE 196A fridge won't drain.. is there a stopper in the drain. This has been the case since I bought it a year ago. When I pull out the veg drawer water under the drawer spills onto the floor and also...
To an evaporation tray. Some have coils to heat the water to evaporate it some have nothing some trays are incorporated into the compressor as it's base.
Oct 20, 2013 | Frigidaire Freezers
After a bottle of gin broke spilling it's contents in the upper portion of our bottom freezer Amana Model BRD18V2S, The refrigerator no longer gets cold, we have aired out the liquor fumes and although the...
My wife posted the information below and I would like to add more to the story: We have two identical Amana Bottom Freezer Refrigerators, Model:BRD18V2S installed in our Kitchen. Both fridges are in an alcove and stand next to each other. One fridge is used as the beverage fridge and othe other is used as a food fridge. At about 10pm she noticed that an entire bottle (600ml) of Gin had cracked and emptied into the refrigerator section of the fridge used for beverages. We do not know how long the spilled gin was in the fridge. She mopped it up and we went to bed. At 7am the next morning, the beverage fridge and its freezer were showing 71 Degrees F. and everythind including the ice had melted. (We have aftermarket external temperature gages that show the fridge/freesor temperatures) The food fridge uninvolved with the gin spill was reading 68 Degrees F
Sep 17, 2010 | Amana Refrigerators
My fridgedaire cannot initiate compressor
Possible start kit bad or compressor. Make sure condensor fan motor working. if not replace it. if ok replace start kit and if still a problem you can bet it is the compressor.
Mar 02, 2010 | Frigidaire FRS26R4A Side by Side...
Frost on back of bottom freezer of a 3 year old kenmore
how long did you leave it unplugged? it's possible all the frost didn't defrost .you need to leave it unplugged and the doors open for at least 12 hrs.
May 20, 2009 | Kenmore 76283 Bottom Freezer Refrigerator
I have a Rca Refrigerator...Freezer on top and fridge on lower half...I noticed a puddle of water a couple of months ago on the floor under the fridge on the linoleum floor..I mopped it up and this...
HI. thanks for your question. the problem is with a clogged drain tube, located under the freezer. and goes down to the drain pan. to repair. turn fridge off for at least 24 hrs. use a small plastic hose . go to the drain hose, by the drain pan. push small hose inside the drain tube, up as high as you can. now blow in the tube to clear. thanks the appliance doc. please rate my answer thanks.
Oct 08, 2008 | Refrigerators
Frigidaire 7.5 cu.ft. Top Freezer the fridge part doesn't cool; freezer is fine.
It should be under warranty, retry he is probably right, run for 24hrs and it should work ok, if you ever defrost you should turn off for 24hrs and leave the door open. Regards Advisor
Aug 08, 2007 | Frigidaire GLRT83TES Top Freezer...
Refrigerators Logo
37 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Thomas F. Schneider
jasbo
jasbo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
