SOURCE: digimax samsung s500 beeps 3 times lens stuck wont stay on
Mine got stuck with lens out. The batteries were new so I never imagined it could be the batteries, but they were cheap ones so I recharged a pair of good ones and once I put tried them on it worked just fine again. Conclusion, the "new" cheap batteries had only enough energy to turn it on and then they couldn't give it enough energy to make it work anymore and that's why I couldn't retract the lens or even turn it off properly. So in your case, try using a couple of good and new batteries.
SOURCE: Panasonic Inverter door stuck
The door latch mechanism is all plastic and commonly breaks. You have to take the cover off and work on it from the inside.
SOURCE: furnace code light flashes 3 times /pressure switch stuck open
Check the intake and exhaust plumbing for any obstructions. I had same issue, turned out to be ice in the air intake plumbing on outside of house. This may be the problem. The pressure switch can be tested by pulling hose from purge motor that goes to switch and applying a small amount of suction. The switch should make a clicking sound.
SOURCE: The lens wont retract(its stuck) thus the camera will not stay on when power button is pushed
FOLLOW this procidure open the camera then rotate the lens and set it like it was before
SOURCE: stuck front passenger seat - wont slide back or forwards due to small screw lodged in floor runner
Be there done that, but with a penny. All you can do is either get real aggressive with a hammer and long metal object as a punch or pull the seat. The seat should have 4 bolts. One at each end of each track. Ising a 1/4 in drive rachet and either a 1/2 or 9/16 socket should work. 1/4 in drive is low profile.. good luck
