Boss Micro BR Digital Recorder Logo
Posted on Sep 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i put my music onto a cd? every
How do i put my music onto a cd? every time i do it only one track plays on the cd.
Fred Yearian
Level 3:
  • Boss Master 5,603 Answers
  • Posted on Sep 22, 2009
Fred Yearian
Boss Master
Level 3:
Answers
5603
Questions
Helped
2250111
Points
16163
Often when recording music CD's you must "finalize" the CD so that the header info of the tracks are written and available to the player.
How do I play a split track cd without the words coming out monitors I want music only
try playing it using a different player, or turning off lyrics in the settings menu of your player :-)
Dec 03, 2014 • Music
Numark NDX400 will not play a flash drive with more than 1 track loaded on it
I had exactly the same problem. You need to press the "Track Push" knob when you have selected the track you want you can then hit "play" to play the track.
Trying to wright some tracks in song mode to cd so i could listen in the car but it will not let me. Any suggestions?
I have a similar Yamaha that makes me re-record the 16 tracks of the song onto the stereo track (left and right) then save. See if under the record setting if it has an option to "record to stereo track" or something similar. Hope that helps.
GEMINI CDMP 6000 5 mounth old 10 times used ( home used ) . Left unit play correct audio CD but right unit have problem with play some tracks from the same audio CD. In Macedonija ( EUROPA ) we dont have...
A call to Gemini is in order here. Given your location, try asking if they will send you a replacement drive. It is common for the drives to contain special uncoding that will prevent a generic replacement drive from working properly. Since this unit is so new, it is likely that the company will replace the drive for you.
Dan
1helpful
What are the exact steps to bounce tracks on the Boss Micro BR
It’s necessary to bounce all of your tracks to a stereo pair of tracks before you can export your song to a computer as a WAV or MP3 file for burning onto a CD.
1. In normal mode, push EXIT and UTILITY until you see BOUNCE on the display.
Note: The upper right corner of the display shows the track you’re bouncing to. By default, “12V2”—Tracks 1 and 2, Virtual Track 2—is selected.
2. Press STOP and REWIND together to go back to the beginning of the song.
3. Press RECORD, and then press PLAY.
4.When the song’s finished playing, press STOP.
i read some stuff online and this should help.
3helpful
2answers
BR-1180 Cd will not burn CD's does it call for
Don't know if this unit is sensitive to the type of CD, but my Phillips recorders will ONLY burn the "Music CD's" (harder to find, more expensive). Read up on the difference of regular vs Music CD's. ALSO some recorders will not burn disks rated at lower or higher rates.
8helpful
4answers
How to use Audioline Pro DJ Multimedia Mixer M Dex 3.0
I have been recently using this Cd Dj deck at parties and have some general knowledge of the product, it has alot of potential. Is there anything in particular that you need help with? Or is it the general concept of using them.
Currently, i don't think there are that many websites that explain how to use the Cd decks, however i can provide you with some basic information. Most of the information here could be worked out by trial & error.
- Pitch control on the right of each cd deck can be slid up ( slows it down %) and slid down (speeding the track up %) i think the pitch control has a range of either +-10% or +-16%.
- Cue button, has the potential for Cue'ing or setting up the cd to instantly jump to the "cue'd" point with the press of this CUE button. This is done by either pressing play/pause button and rotating the jog wheel to a point of time in the track which automatically sets the cue point OR holding down the >> or << search button to find a spot within the track at a greater speed.
-Vinyl mode. Pressing this button will set the deck to the "vinyl mode" to simulate scratching or even backspins. pressing this button again will change the mode back.
- the Crossfader (or 'X' fader) button will select the left cd track if the x fader is all the way to the left and the right track if the x fader is all the way to right. having the X fader in the middle will play both tracks together.
- Low, Mid, High. These nobs on the middle section of the deck change the individual track by which it is corresponds. (Left side = left cd track, and vica versa) Low refers to the Bass of a track which can be essential for mixing two tracks and elminating excess bass noise. Mid refers to the drumming and even synth of a track, and changing this can result in some cool sounding effects. High refers to the 'high' frequencies of the track playing, such as snares, hi hats and possibly vocals. All these controls are crucial to understand in order to mix 2 songs together successfully. It's good to get a chance to muck around with these cointrols. The middle of each control resets the setting to normal or default.
- Channel fader. the two controls that slide up & down on both sides of the mixer on the deck. This is also referred to the volume setting. Useful for mixing seamlessly one track into another.
- Gain. This control at the top of the mixer refers to the volume level or 'gain' of the cd track that it corresponds to.
- Jog wheel. Serves 3 purposes. firstly it can be used whilst a song is playing to temporarily speed up or slow down the track to match with the song on the opposite side. secondly, whilst holding down the 'search' button, operates as a control to quickly find a spot in a song. and lastly when selecting "vinyl" mode, can simulate the reaction of a vinyl turntable. The scatch function, and backspin effect.
- The pitch button, is just another control to speed up or slow down a song temporarily whilst holding down the '+' or '-' button.
- Reverse button, for a certain amount of time will play the song on the left or right in reverse.
- Time. this button is essential to change the time selection on the cd deck, to either "Time elapsed", "Time remaining" and "total time remaining on the cd".
- the "tap" button, allows the user to physically "tap" the button in time with the song's beat, which calculates the Beats per Minute (Bpm) of that song. which is essential to work out the bpm of 1 track to mix the speed with that of the opposite deck.
- Cd/usb/sd, changes the mode of system reading. from CD to USB or SD card.
I really hope this general guide to using the Audioline ProDJ MDex3 has helped!
Peace. Marc.
Apr 03, 2009 • Music
1helpful
2answers
I can record anything to a cd with my boss 1180 br it always say
Im Guessing Your Trying To Burn It Off Before Mastering It Which Means All The Tracks Between 1 And 10. First You Click Audio Cd Write/Play Then Select Disc At Once And Then It Should Guide You From There. I Hope This Helps
www.Myspace.com/CrossRoadsToNowhere2007
Boss BR900CD External MIDI
I'm not totally familiar with that Boss Digital Audio Workstation but it sounds like what you want to do is record both the music and vocal track at the same time. If that's the case I believe you can push both "Line" and "Mic" input buttons (perhaps not exactly named as such) at the same time to record both simultaneously. Otherwise I would suggest copying the music to it's own stereo track (or two individual tracks, each panned opposite from one another to maintain stereo) and then record your vocal track separately. That way you can record several takes and edit down the best parts to one final track.
I hope that helps.
Top Boss Music Experts
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
ADMIN Eric
ADMIN Eric
Are you a Boss Music Expert? Answer questions, earn points and help others
