Computers & Internet Logo
Leora Allison Posted on Nov 28, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i delete names from my greeting card list. i am already a member
Not Me
Level 3:
  • Computers & ... Master 3,158 Answers
  • Posted on Nov 28, 2019
Not Me
Level 3:
Answers
3158
Questions
0
Helped
163349
Points
31816
Please understand that you are talking on a public forum to regular people who offer advice, not to the company that you signed up with. Contact them directly for support
1 Related Answer
nonontech
Lebanon Raingam
  • 4737 Answers
  • Posted on Dec 09, 2010
SOURCE: We have upgraded to outlook
This happens when the installed updates has some missing files or wasn't updated properly. I don't mean you didn't install the update properly, but it might happen without your knowledge.
You can try updating the program with the same installer you used to update 2007. If that doesn't fix, then the only solution is reinstall the program after the contacts and other important files are back up (exported).
There is no patch or hotfix available for this issue.
If you have many contacts, then it's not recommended to do it manually, but if they are less than.. say 100, then, Adding them again will take less time than backing up and doing this and that..
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Microsoft Teams add member in Team.
To add a member into a Microsoft Team go to the team name in the team's list and select more options. You should see the option to add a new member, click this and start typing a name. After you have finished adding members click add and then select close. The people you have added will now show up in your team's list.
I've been a member for several years but recently am unable to 'preview' Greetings cards. Please help me.
A member of what ? You may have directed this query to the wrong recipient.
Sep 10, 2016 • Cameras
1helpful
Have a receipt from walmart for a greeting card. is there anyway to tell what kind of greeting card I purchased?
If the receipt lists the bar code number of the card YES. If the receipt only lists the purchase as a card NO.
2helpful
How do I delete photos off of the card after I have saved them to my computer?
If you have connected the scanner .... using the mini-USB port at the back of the scanner ... to your PC, and you have already downloaded (copied) the photo directly off the card to your computer ... you can select the photo's (on the card) that you do not want (e.g. click on the item / icon list) ... and press DELETE ... like you're deleting a file off one of your folders/directories. You will be shown a pop-up window asking you to confirm if you really want to delete those (selected) files (photos). Click on YES.
Yes, the PC sees the contents of the card as a "list" of files in the (card) folder. So, just delete the photo's (files in the card) folder like you would delete any file.
If you have the card (removed from the back of the scanner) and inserted into your PC (e.g. via a USB card reader) ... and you have already (selected and) copied the photos (files) to your computer, you can do the same (as above) to delete the photos off the card. That is, select the photo's you want to delete (by clicking on the icon or item listed) and press the DELETE key.
1helpful
How do I record a greeting on the Uniden cxa/5698?
With the phone in standby, press [greet]. While the preset message is playing, press and hold [greet] again. You will hear the announcement "Record greeting" and a confirmation tone.
If you already have a greeting recorded, you can delete the current one and then record a new greeting. While the current greeting is playing, press (delete). And then start over with the first.
Start recording your message. You will have thirty seconds, and the message counter will count down.
When you are finished recording your greeting, press [greet], (play/stop) or [set]. You hear a confirmation tone, and then your greeting plays back for you.
The full instructions begin on page 45 of the manual.
How to assign a different ring tone for specific contacts on Nokia 5230
Groups can contain any number of contacts, and even just a single member, so you could, for instance, have one ringtone for family members, one for work colleagues and one for your partner.
To create a group, assign a ringtone and image and then select a group's members, follow these instructions:
  • From the main menu, highlight Contacts and click Select.
  • Highlight Groups and click Select.
  • Click Add (or if you have already added groups, click Options, highlight Add new group and click Select).
  • Enter a name for the group and click OK.
  • Highlight the group's name in the list and click Options.
  • Highlight Group details and click Select.
  • Highlight Group ringing tone and click Select
  • Highlight Open Gallery, click Select, locate the ringtone in your gallery and click Select to apply.
  • Highlight Group image and click Select.
  • Click Add, highlight From Gallery, click Select, locate the image in your gallery and click Select.
  • Now highlight Group members and click Select. Click Add and your contacts list will open. Highlight the contacts you want to add to the group and click Select. You can add as many contacts as you like to each group.
If you want to add contacts to an existing group, highlight the group's name on the Groups screen, click View and click Add to display your contacts list. Highlight a contact and click Select to add them.
1helpful
The automated recording that comes on when the lines are full needs to be changed and the recording of an employees name on the directory needs to be changed. I have already changed the display name on the...
The persons name is recorded in their personal mail box.Thats done by pressing open voicemail or feature 981 followed by their password, press 8 or admin and press 1 to re record thier name in the company directory.
To re-record greetings, enter Feature 983. if your system has 2 digit intercom #s your default password is 120000 if your system has 3 digit intercom #s your default password is 1020000. once you have entered the password you will see 3 selections you can make .use the three soft keys under the display and select AA (auto Attendant). next press greeting and greeting again. next it'll ask for the greeting number your probably working with greeting 1. press record to start and ok when finished. dont forget to save the greeting or it will be deleted if you exit early. hang up when finished.
Unable to install software
Are you able to go to my computer, then to c:/ drive, then go to program files. Look for the uninstall file.
You can also go to start menu, search, type in the file name and search it, once found, delete everything listed.
The 3rd way is to go to start menu, go to run, type regedit, then find H_KEY_LOCAL_USER, then scroll down until you find the software tab and then click the + sign to expand the list with all your software. Once you find the program file, right-click on the file and delete it.
Then go back to the main list, go to H_KEY_LOCAL_MACHINE, find the software tab, and find the program and delete it. Then exit the program, reboot your pc, and now the program will be gone.
2answers
Ds i have a r4 which already has games loaded onto
Insert your sd card into the computer/laptop using the sd card adapter and open the file then click on the file named games. Downlaod your games you want from online sites and put them into the folder named gamnes.here you can also delete the already existing games or even add music by creating a new folder called music not in the games folder though.
Cannot remove greeting card 2 . therefore cannot cannot put in Greeting card 6 . I go through the correct sequence but get a message intenal error 2738.I am 83 and hope you can help
remove the program in the windows registry.
click start
click run
and type regedit
after the registry program opens
click edit
click find
type the program name e.g greeting cards
click find
delete every file that you found in the registry that belongs to the greeting cards program
after you delete close the registry program and restart the windows.
and then try to reinstall the new program..
i hope it will help..
Grand Canyon Tech
Grand Canyon Tech
