Error SC 282-13 on a Sawgrass GS 1000 printer typically indicates that the printer is experiencing a problem with the print head assembly. Possible causes of this error include:
A problem with the print head: The print head may be damaged or malfunctioning, causing the error to occur. If the print head is damaged, it will need to be replaced. If it is simply malfunctioning, cleaning the print head may resolve the issue. To clean the print head, follow the manufacturer's instructions for your specific printer model. This may involve using a cleaning solution or simply running water over the print head.
A problem with the print head cable: The cable that connects the print head to the printer may be damaged or not securely connected, causing the error to occur. If the cable is damaged, it will need to be replaced. If it is simply not securely connected, make sure that it is properly plugged in on both ends.
A problem with the print head alignment: The print head may not be properly aligned, causing the error to occur. If the print head is not aligned correctly, the printer may not be able to print properly. To fix this issue, follow the manufacturer's instructions for aligning the print head. This may involve using the printer's built-in alignment tool or manually adjusting the print head position.
If the error persists after trying these steps, it is recommended to contact Sawgrass customer support for further assistance. They may be able to provide additional troubleshooting steps or arrange for service if necessary.
The error code SC20502 on the Sawgrass SG1000 printer indicates a problem with the ink system. The grinding/clicking noise coming from the ink side of the printer suggests that there may be an issue with the ink cartridges or the print head. This error code can also occur if the ink cartridges are not properly installed or if they are empty.
To resolve this issue, try the following steps:
1. Turn off the printer and unplug it from the power source.
2. Check the ink cartridges to make sure they are properly installed and not empty.
3. Check for any obstructions in the ink system, such as paper jams or debris.
4. Turn on the printer and see if the error code has cleared.
If the error code persists, it may be necessary to contact Sawgrass technical support for further assistance.
It is important to note that attempting to fix the printer yourself may void any warranty or service agreements you have with Sawgrass. It is recommended to contact their technical support team for assistance.
1) The error code 20230 on the Sawgrass printer shows there is a jam in the fuser.
2) To solve the problem, you need to remove the fuser from the Sawgrass SG800 printer.
3) Power Off your Sawgrass printer by force pressing its Power button. Ascertain that all the flags can move freely and check if they can stay in contact with each other.
4) Pull the fuser out of the device and discard the oil housing.
5) Tilt the paper width guides and check if the exit flags can move freely.
6) Reinstall the fuser and then press the Power button to switch On your Sawgrass printer.
