The manual only refers to FL:C (factory default setting) and FL:A (alternative setting). Also it says Mode button will toggle between FL:C and FL:A. In my case it only toggles between FL:A and FL:O.
SOURCE: K700i Toggle Button fix?
Yes, you can get it cleaned and that must work for you. The toggle button for the Sony Erricson phones do have issues; the toggle button wears out. If cleaning does not help, you would be able to get a replacement for the button. cheers
SOURCE: Cannot toggle Flash Mode
look for the 3 boxes icon (multiple shot mode) on your lcd screen at the top. Toggle the button for this (by the shutter button) until it goes away. this has 3 modes. My wife does this all the time!
SOURCE: backlight fading
you can adjust the brightness by pressing the Fn button along with the *left/*right button on the right side of the keyboard
SOURCE: Aspire Digital AD-N820B DVD-R stuck in Progressive Scan ( PSCAN )
I just had the same problem with the same model but I was able to figure it out after a while.
From the remote control:
SETUP
Scroll left or right to the PREFERNCES menu.
Scroll down to the bottom until DEFAULT is highlighted.
HIt the PLAY button in the remote while RESTORE or RESET is highlighted.
The DVD player was reset back to factory settings within 10 seconds.
SOURCE: right toggle, down is up, up is down, toggle setting defualt
Look at theLook Inversion in the Game Options Setting, Change it from on to off.
Most laptops will show the desktop on one or both screens You can use function keys with common combination such as Fn + F5, Fn + F3, Fn + F8 and Fn + F9 to toggle between the two screens. Refer to the laptop's user manual for the right key combination to toggle between the displays. Alternatively, with many laptops you can also switch to the extended desktop mode. This means your desktop screen will be stretched across both the monitors. Refer to your user manual to switch to this mode.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy New Year!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
MODE (LONG PRESS-4 SEC) TO ENTER INTO SETTINGS;
UP/DOWN TO CHANGE THE PARAMETERS; \
*C/*F KEY TO TOGGLE BETWEEN TO TEMPERATURE FORMAT;
SNOOZE BUTTON TO SET SNOOZE IN ALARM-MULTIPLE SNOOZE CAN BE SET;
RESET KEY CAN BE USED TO RESET CLOCK TO DEFAULT;
DAY COUNTDOWN , AND TIME COUNTDOWN CAN BE ADJUSTED;
DETAILED INFORMATION TO SET THE CLOCK
INSERT CELLS;-SCREEN SHOWS DEFAULT VALUES-INITIAL MUSIC WILL RING;
LONG PRESS MODE BUTTON-KEEP IT PRESSED UNTIL 12 STARTS BLINKING;
USE UP /DOWN BUTTON TO ADJUST HOURS...
THEN SIMPLY PRESS MODE AGAIN, NOW MINUTES 00 IS DEFAULT WILL START BLINKING;
USE UP/DOWN BUTTON TO ADJUST MINUTES;
AGAIN PRESS MODE, SCREEN WILL SHOW YEAR 2002 DEFAULT BLINKING, USE UP/DOWN KEY TO ADJUST YEAR;
AGAIN PRESS MODE, SCREEN WILL SHOW MONTH BLINKING, USE UP/DOWN KEY TO ADJUST CURRENT MONTH;
AGAIN PRESS MODE, SCREEN WILL SHOW DATE BLINKING, USE UP/DOWN KEY TO ADJUST YEAR;
AGAIN PRESS MODE, SCREEN WILL SHOW 12:00 BLINKING WITH ALARM SIGN (FOR ALARM SET);USE UP/DOWN KEYS TO SET ALARM, FIRST HOURS AND THEN MINUTES FOR ALARM; THEN ON PRESSING YOU CAN SELECT SNOOZE MINUTES;
AFTER SNOOZE ON PRESSING MODE AGAIN YOU CAN SELECT DAY COUNTDOWN TO SELECT 999 DAYS COUNTDOWN FROM CURRENT DATE;
when watch displays time and everything .....
each and every buttons has some function;(shortcuts)
press down to toggle between 12hr/24hr format;
press up to enter contdown timer;
press snooze to set snooze in alarm;
press c/f to toggle between two temperature formats;
press mode to toggle between alarm time and current time;
Are you misreading the C as an O ?
