Televison & Video Logo
Anyandwile Mwasenga Posted on Dec 01, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Sony CRT TV produce red picture that shakes, I have tried to adjust on FBT without success, please help me
Dariusz Zalewski
Level 3:
  • Master 1,095 Answers
  • Posted on Dec 01, 2019
Dariusz Zalewski
Master
Level 3:
Answers
1095
Questions
0
Helped
297209
Points
3055
Possibly tv reach its end. Save money and replace it with modern energy efficient tv.
5 Related Answers
A
Anonymous
  • Posted on Dec 31, 2007
SOURCE: HITACHI Projection TV 53FDX20B having too much red color
my hitachi projection big screen tv 57SWX20B has a draping affect across top of screen why?
Louis faenzi
  • 133 Answers
  • Posted on Mar 01, 2008
SOURCE: Panasonic Rear Projection TV - PT-47WXC43G Convergence Problem
The tube should be ok its the IC's regulating the convergence is your problem . A tv repairman should be able to repair it fro around $250.00 - $300.00 or less depending on who you call. Good luck
Jaime Hernandez
  • 2351 Answers
  • Posted on Apr 21, 2008
SOURCE: red crt needs manual calibration
You can download the service manual from here.
Slinteriors
Sonny Berry
  • 8617 Answers
  • Posted on May 27, 2008
SOURCE: Convergence adjustments
Replace both convergence ICs nuber STK392-040 that should take care of the problem. you can get new replacement ICs at the following link and they will send free instalation instructions with pictures so you can install the new ICs. heres the link.
http://servicemanuals.vstore.ca/
Anonymous
  • 197 Answers
  • Posted on Jun 07, 2009
SOURCE: Sony Grand wega KDF-E50A10
bad lamp
1helpful
MY TV PICTURE HAS GONE A LITTLE DARKER AND ADJUSTING BRIGHT, CONTRAST, COLOR,ETC. DOES NOT HELP
How long u have this RCA analoge tv?Around 10 years or more and used it like about 5 or 6 hrs everydays?Yes,than ur tv it is losing CRT tube radiation cohetion.As times go bye years in years out the tv CRT-(tv tube) radiation will slowly dying out,Tv actual pictures will lost some of it luster and it brightnesses to the tv auctual pictures.Brightnesses of CRT tube will get darker and darker until the tv actual pictures barely it is watchable anymore.Contrast,Brightness and Colors adjusting more will help some.But u have to take this tv aparts and take a Flat scerw driver turn up a little bit more of the tv HV-(high voltage) SCREEN button on the FBT-(flyback transformer) to make any big differences of the CRT tube brightnesses.The FBT-(flyback tranformer) is the big block of plastic with a red wire with a black cap hook up to the tv CRT-(tv tube).This adjustment on of the FBT,HV-SCREEN button will help the tv CRT-(tv tube) last another year or two.
2answers
My sony kv-36fs13 picture is very red. I tried adjusting the hue without success. I am getting the little red light on the front of the tv blinking five times. Any ideas?
open the back cover of your TV (unplug the unit) using a soldering Iron,resolder all the components at the CRT socket .the small square board attached to the tail of picture tube That's it! good luck and please dont forget to rate I need it to keep going...
2answers
When I turn it on, it makes a buzzy noise but nothing else., no picture or tv sound.
The set has a high voltage problem, "the flyack transformer is defective" It generates the high voltage in the picture tube and with the help of the video circuits it produces a picture. It is not cost effective to repair the tv, cheaper to replace.
White lines on the screen.sounds ok.picture is coming behind white line.
Lines means Screen Drive is overdriving, try adjusting the Screen control on the FBT flyback Transfomer, adjust it down. If that does not Clear out Problem then replace the CRT Board that is connected to Picture Tube.
I have " Sony FD Trinitron WEGA KV-36HS420 36" TV
U have a soldering iron,desoldering pump or a roll of desoldering braids,a roll of solders?Can u do basic soldering and uderstand basic electronic?FBT- the flyback transformer,the big black block of a plastic with a red wire with a cap hook to a CRT-tv picture tube.Near the big block of a plastic with a red wire with a cap hook to a CRT picture tube.Inside to the right of the FBT,there are 2 power supply ICS,those 2 ICS are dead.Replaced these 2 power supply ICS near the FBT,will solved this tv LED power light indication blinking and will have stable tv power again,and tv will work.
Picture gets bright then blinks black, adjusts and then gets bright and blinks again every 4 seconds. used to be every couple of minutes.
Take the tv aparts.Caution high voltage ERA FBT.The FBT the flyback transformer.That the big block of plastic,with a red wire with a cap hook to the CRT(Tv tube).On FBT that big block of plastic there are 2 knobs one said FOCUS the other said SCREEN.Turn knob said sceen down a bit,will stop get very bright pictures and shutdown,the screen will hold high voltages.
2answers
Picture out of foucs
HIGH VOLTAGE WARNING - open the tv and on the flyback Xformer, there should be a knob that is labeled FOCUS try adjusting it. the flyback has the red wire on top that goes directly to the the top of the picture tube.
PICTURE CUTS IN AND OUT
Ur video board CRT socket pins resoldiers that.
Ur hight voltage transformer,FBT(the big block of plastic with a red wire with a cap hook to ur
CRT.Bottom of that plastic block of that there pins resoldiers that too.U should solve the prob.if not, the FBT must be replace it dead.
8helpful
KV-HX32 SONY WEGA TV
The hight voltage transformer it dead.The FBT(The flyback transformer is dead)The block of plastic with the red wire with a cap hook to the CRT(the tv tube).
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
