Drills Logo
j
judith stanley smith Posted on Dec 01, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have just bought this tool and can't see any instruction of how to open it (no chuck key point)so I can fit one of the tools in- can anyone help?? Thanks!
  • judith stanley smith
    judith stanley smith Dec 01, 2019
    Rotacraft RC-18 It has instructions but the instruction don't open the ring so that I can insert the tool. I have now solved it with the help of a friend! I was being too gentle with the unscrewing..
  • Terry
    Terry Dec 01, 2019
    https://www.youtube.com/watch?v=rT8w5RRD... - similar model
Terry
Level 3:
  • Master 11,377 Answers
  • Posted on Dec 01, 2019
Terry
Master
Level 3:
Answers
11377
Questions
Helped
4625087
Points
152765
What make and model drill is it, please? You can use the Comment menu to add information to your question, or to ask additional questions.
5 Related Answers
Anonymous
  • Posted on May 01, 2009
SOURCE: nokia 7380 fix !
See this post for information:
http://brokenappliance.blogspot.com/search/label/Nokia%207380
Anonymous
  • 843 Answers
  • Posted on Jan 19, 2010
SOURCE: i need a chuck wrench/tool for a duracraft drill press
Are you talking about the chuck key? That's the little wrench with a collar of gear teeth on it.
There are only a few standard sizes plus a couple of odd-balls. Last time I looked, Sears carried a good selection. If you have the old one, take it with you to the store. If you don't have the old one, find a way to measure or approximately measure what you need. Another chuck key that doesn't fit can be a useful reference. If you can find something (maybe a drill bit) that is a close fit into one of the three holes in the chuck, that can be useful too.
Anonymous
  • Posted on Feb 02, 2010
SOURCE: how do i remove the chuck from dewalt dc925
The dc925 and the current model dcd950 along with several other models of Dewalt 's line of cordless hammer drills DO NOT have a screw inside removal requires a CHUCK REMOVAL FIXTURE part #
233804-40 also you can't use a generic replacement chuck. As of 2/2/2010 the prices on the Dewaltservicenet web site are $72.74 for
the tool and $69.70 for the chuck, part # 330075-90.
Anonymous
  • 44 Answers
  • Posted on Mar 20, 2010
SOURCE: Need fitting instructions for Nokia E63 replacement full housing.
get through your user manual provided with thw purchase of your mobile phone.you can find the instruction for replacement of housing....better to get a help of trained service engineer
Anonymous
  • 3 Answers
  • Posted on Sep 26, 2010
SOURCE: dremel moto tool model 395 coupling from motor to
The part that goes between the motor and the chuck is called the CLUTCH UNIT,
REF 2615294309 it is a splined rubberised sleeve, it also fits the 276 and 396.
The price is £3.69 (including vat at17.5%) and can be obtained from Jaymac (Derby) Ltd.
http://www.dremel-direct.com/acatalog/service.html
1helpful
Any one know where a chuck for Hitachi Power Tools Ds14dvf3 can be purchased, it is a discontinued item, and no parts seem to be around? OR is there a universal chuck that could be used in this drill?
I'm hoping you mean a chuck "key" .... there are only 4 different sizes and can be bought in tool stores as universal chuck keys tool 4 in 1 tool...
Changing the chuck of a 6408 makita electric drill
Open the chuck and remove the screw inside the chuck (if fitted) the screw is left hand thread, fit the short end of the largest hex key that will fit into the chuck and tighten the chuck, put the drill into low gear and turn the clutch to the drill position, support the drill on a bench and strike the long end of the hex key with a firm blow (right hand thread) it may be neccessary to strike it more than once
What is the size of the replacement chuck key for the Duracraft DP514?
The 1/2 inch is the max size drill that will fit into the chuck. There are only a few different key sizes, and sears sells them in their tool area. Easiest thing to do is find the size of the hole the chuck fits into by using the back end of a drill bit that fits the best. Measure that drill bit or take it with you to the store. You might find two different size keys with that size pilot hole, or maybe only one. Good luck!
Dec 27, 2012 • Drills
2answers
Replace Keyed Chucks with Keyless Chucks
Can't help with this other than suggest that you do not proceed, Keyless chucks can be problematic particularly if dust /debris from material being drilled finds its way into the chuck..
Mar 30, 2017 • Drills
2helpful
Can the chuck be repaired? The very top part (plastic) has fallen out, everything else is intact. Thjis is the ring that you hold while adjusting the chuck. Is it worth getting repaired?
Yes you can get a replacement chuck and install it your self. with the chuck open, ( you can still make it open but its not easy inthe bottom of the hole theres a screw that holds it from turning , most of them ar ebackwards thread, ( turn it ti the right to loosen ) with the screw removed and the drill in low gear ( the slower of the two speeds chuck up the short end of a big allen wrenck ( kex key) The chuck has regular threads and you smack the key with a hammer to unwind it. once turning it'll come right off. If you can't get it off it's not worrth fixing as if you need to pay a shop to put it on by the time parts and labor go by a new one can be bought. You might not be able to get the Ryobi chuck but don't worry all the chucks with the same thread sise will fit and work even ones that use keys. they come with both metric and inch threads though so be sure you take the old parts with you to the stroe to match them up. Msot places that rent out tools have a fix it and parts shop too. Look them up under tool repair and tool rental.
I have a McCraw Edison 1/2 drill model 3241T2and need a new chuck where can I find one.
If your chuck is a stanard type, fully open the jaws of the chuck and look inside the chuck to see if there is a retaining screw.
If there is one remove it (more than likely it will have a reverse thread).
Using the chuck key in the chuck, knock it with an hammer to loosen it.
You should be able to get any chuck from a local tool shop to fit your drill.
Regards
Alan Hood
ami-man
UK
Feb 09, 2010 • Drills
6helpful
I need a chuck wrench/tool for a duracraft drill press
Jan 17, 2010 • Drills
Can't open the chuck in my milwaukee power drill
hi,
it might be possible that the chuck is dry due to heat build up while being in use. if it has set up for a while it is also possible the chuck has rust in it. i would use some penetrating fluid in it and let it set a day or two then retry opening it. if it doesn't solve the problem then i would take off the chuck and soak it in diesel fuel or kerosene over night. if it was working good before this will most likely fix you problem. if it does then be sure to apply alittle bearing grease to the inside chuck keys. this will keep it moving freely. good luck!
2helpful
Faux men's rolex date just
An authentic Rolex will have a screw down back with exactly 144 small teeth. You can only open a Rolex case with a special Rolex tool (Key). We use the Bergeon hand wrench to open Rolex cases. Supplied with 6 Bergeon grooved chucks(18.50, 20.20, 22.50, 26.50, 28.30 and 29.50 mm), these are the same chuck used in the Bergeon 5700RO and will fit in the Bergeon Bit Adpater for 5700-Z Case Opener our number FB-231. Replacement chucks and replacement handle are available in case you have a set that is missing a piece. As is the case with any fine mechanical instrument, special tools are required in order to properly service and adjust a precision instrument such as a fine timepiece. If you are not experienced, it is better to leave this to a Certified Rolex tech. If you do feel you want to proceed, this tool will set you back about $140.00 or so. Just as the internal parts of the Rolex are exact, so is the watch case that protect the valuable watch movement. These tools are used to open the Rolex case without causing expensive damage. You can call Bob Frei at 510-832-0355 ext. 2 from 11 AM to 5 PM Pacific Time Zone, to order one if you wish, or several other sellers of these fine tools can be found by doing a little research on the net. Hope this has helped you.
Top Drills Experts
ADMIN Andrew
ADMIN Andrew
john h
Steve Pack
Steve Pack
Are you a Drill Expert? Answer questions, earn points and help others
