SOURCE: emerson tv codes for GE RM-24930 4-Device Universal ...
check this site for your codes. (Jasco is GE)
http://www.jascoproducts.com/support/universal-Remote-codes.asp
SOURCE: universal remote
Codes for Panasonic TV.....171,148,054,170,062,374,381,437,003,070. You can Goggle the programming info...Just ask...How do I program a GE Universal Remote... There are about 7 steps...easy if these codes work....good luck...I have a remote that none of the given codes are working........
SOURCE: GE Universal Remote - Have codes, not working
you will need to manually find the codes with a code search. If you do not have the owners manual, let me know, I will attempt to find it for you and post a link. Let me know
Please take the time to rate this solution.
clarkco
SOURCE: i have lost the ge universal remote guide for the
These are the steps on how to program your GE Universal Remote Control without the list of codes.
1. Manually turn on the device to be
controlled.
2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
3. Press and quickly release the desired device button. The red indicator blinks off once.
4. Press the ON•OFF button repeatedly (up to 300 times) until the device to be controlled turns off. The red indicator blinks off with each button press.
Note: Code Search starts from the currently stored four digit number under that mode. Sometimes the
first code that “works” with your device may only
allow limited functionality (e.g. the MENU button
might not work). There may be a code that performs
more functions. Continue the code search process
until the best code is found.
5. Press and release ENTER to install the code.
SOURCE: I have a ge universal remote model #24110R need tv code
http://www.jascoproducts.com/support/universal-remote-codes.asp
