Building Materials Logo
Alysha Simone Posted on Dec 01, 2019
I have a problem with my garage opener. It blinks and stops working while I press the remote control. It only works when I hold the button by the door. Do you have any advice on this matter?
Wayne Tolonen
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 01, 2019
Wayne Tolonen
Contributor
Level 1:
Answers
Questions
0
Helped
126
Points
Low battery in remote.
13helpful
1helpful
The door wont work with the remote. it will only work by using the pad that is mounted in the garage.
Make sure the small light in the wall control is not blinking. If so press and hold the lock button on the wall control for 3 seconds. This will stop the blinking and your remotes will work.
R garage door opener model 139.53640srt -remote car openers wont work suddenly. have to open using the house opener, whose light is blinking
Press and hold for 3 seconds the lock button on the wall control. The light should stop blinking and your remotes should now work.
I have a 1/2 hp craftsman opener. Remotes work fine. Wired wall unit has a blinking light on the open button and will not work Lock pad and light pad work but not the operate pad.????
Try pressing and holding the lock button for 3 seconds to stop the light from blinking. Your wall control may be bad. Usually when that light is blinking it is the remotes that will not work.
2helpful
My wired key pad in the garage opens and closes the door but the buttom keeps blinking fast. My two car remotes stopped working. My remote key pad on the house works. Whats with the fast blinking and...
Press and hold for 3 seconds the button on the wall control that has an icon of a lock. The light should quit blinking and your remotes will once again work. Holding that button for 3 seconds toggles your openers vacation mode.
Garage door don't open
On the wall control press and hold the button with the lock icon for 3 seconds. The blinking should stop and your remotes will once again work.
9helpful
My keypad works,my remote opener does not, even
It is related. One of the buttons on your wall control is the lock button and has a lock icon on it. Press and hold it for 3 seconds. The blinking should stop and your remote should now work.
All remotes stopped working on genie opener, hardwired wall switch works fine.
Your lock on the opener is probably engauged. On the wall control there is a button labeled lock. Press and hold this button for three seconds. Your remotes should work now. If they still do not work, you need to reprogram the remotes. Press the learn button on the back of the motor and then press and hold the remote button. The light will blink once. Repeat this step on the other remotes.
Top Building Materials Experts
Steve Pack
Steve Pack
ADMIN Andrew
ADMIN Andrew
Are you a Building Material Expert? Answer questions, earn points and help others
