Hi. please help me if you can. ive been asking everyone i know for help and nobody seems to know, even mechanics!
the problem is in my jeep wrangler only my 10" sub is giving off sound and its all bass so you cant hear any high sounds that the regular speakers usually give off. I installed the system myself. I have a kenwood stereo, dub 550w mosfet amp, 4 sony tweeters and 1 10" mtx sub. They all worked at one time but the past few days either they worked or didnt and now they dont work at all, just the sub. The sound is very bad as its only a deep bass sound. I tried playing around with the settings on the amp but nothing works.. the crossover settings dont work, the frequency range doesnt work... or should i say doesnt make the tweeters work. I can rule out that it is not the amp that is the problem because I went and bought a new amp and hooked it up today and that didnt work, it was the same as before so that is not the problem. Please help!!!
Could be bad outputs from the back of your head unit or also could be bad rca cables. Make sure the amp is on and powered.
Check setting on the head unit if you have SUB settings. Make sure amp is bridged running 1 channel combined not 2 seperate, Make sure RCA leads are plugs in correctly and not backwards, turn do the power on your amp, turn SUB volume down on your amp.
same, cant figure it out!
