Hello to all ! Radio Pioneer AVH 1330 NEX. Unable to update firmware. Writes that an unreadable file. I did everything according to the instructions from the official site. I tried a hundred options !! Nothing helps !!!
SOURCE: Wrong sim card problem with SE P910i, not P900 but pretty similar anyway
I don't have a solution, but my P910i did this immediately AFTER I did the firmware upgrade. The local repair shop refuses to look at it as the tag and internal IMEI numbers are different. I suspect it was repaired before and the tag not changed. I am still working on it and will let you know. But its xmas and Australia rolls up the sidewalks shuts off the streetlights and stops.
SOURCE: Archos 605 Recovery code 108
1. Download the latest firmware from Archos
2. Format the drive on your player
3. Connect the A605 to your computer using the USB lead
4.
Copy the new firmware the A605's root folder (Drive X: on your PC or whatever letter was assigned to your Archos
5. Click ok and you are finished
SOURCE: eject lock pioneer avh-p5000
Turn it off so you see the "demo" screen or the blank "off" screen, then hold eject + volume (mute) button down for few seconds to turn the eject lock off.
SOURCE: pioneer AVH-P5700 instalation
You can find a wiring diagram for your 87 monte at http://www.modifiedlife.com/1987-chevrolet-monte-carlo-car-audio-wiring-schematic/ You can refer to the installation manual for your deck at http://akamaipix.crutchfield.com/Manuals/130/130AVHP570.PDF Since you are removing a shaft style radio and installing a DIN style you will need to perform extensive modifications to your dash. The Pioneer manual provides the dimensions.
SOURCE: My GC820 is not working
The firmware does not need to be updated. After a mode is selected by moving the mode slider switch left or right then depress that same mode slider switch like a button. When the mode switch is used to change a mode but one does not press it in to select it, that is when the play button changes colors.
