Washing Machines Logo
Christine Pratzky Posted on Dec 03, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi our washer wont fill up on any of the wash cycles, it fills on rinse cycle then I put it back to wash once full and it will wash and continue as normal 1??
  • Christine Pratzky
    Christine Pratzky Dec 03, 2019
    It's been used every day for years never missed a beat only ever used cold water it does everything but fill with water on wash cycles only
ChinthakaJ
Level 3:
  • Master 943 Answers
  • Posted on Dec 03, 2019
ChinthakaJ
Master
Level 3:
Answers
943
Questions
Helped
301293
Points
2783
Whats the make & model?
1helpful
Spinning cycle
Keeping in mind that the soap & bleach gets dispensed into your wash on the second to last rinse cycle and that most all rinse cycles are in cold water. Is your cold water valve screen plugged causing your washer to rinse poorly? Are you using the HE detergent? If not maybe the washer is sudsing up to much and having a hard time rinsing all the suds and bleach out and leaving the clothes soapy.
Fill the washer up with no clothes in it on a cold/cold wash setting does it take a long time to fill the washer up? Also when it is full and agitating is there suds in the washer?
Last suggestion is if the drain is hose is a lot higher than the top of the washer it might have a hard time draining out all of the soap water before the next load
6helpful
Washing machine wont hold water on any setting
raise the main drain hose to the top of the back control head. there may be a problem with the main hose being to low and the water is gravity siphoning out of the washer.make sure the washer is off when you lift the hose up but do not remove it from the wall,you should here water drain out once it has stopped draining restart you machine and it should fill to the proper level and quit then go into your wash cycle
1helpful
Agitator starts at begining of cycle before washer is full
Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
Quentin
5helpful
2answers
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
2answers
Washer fills slow only in the rinse cycle
I had the same problem with my Kenmore Model 11022956102 washer and first thought that it was the water inlet valves. So I replaced them, but found the problem continued. After about 25 seconds into the rinse cycle the water only trickled in. Checking with a voltage meter I found that I lost 120V at terminals 3 & 5 on the washer temperature controller after 25 seconds. Even though the wiring diagram doesn't show the water temperature control board, since it's full of resisters and capacitors, I figured it was the most likely problem. So I ordered a remanufactured board from Parts Simple (#3407125), received and installed it. The 17 year old washer is now working fine once again. I hope this helps someone with the same problem. /s/ Paul
Shutting down on rinse cycle
Hi this could means that you may need to replace the washing machine bearings. Once the bearings are bad, the motor overheats and it will automatically shut down after the first rinse.
Timonty from WashingMachineAdvisor.com
Top Washing Machines Experts
john h
