Hardware & Accessories Logo
J
Joseph McDonough Posted on Dec 03, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sylvania timer sa011
How do I set the timer
Mehandi Husain Suleman
Level 3:
  • Master 1,654 Answers
  • Posted on Nov 23, 2021
Master
Level 3:
Answers
1654
Questions
Helped
576574
Points
4530
Hi
find link for manual for sa011
https://www.manualslib.com/manual/1704914/Sylvania-Sa110.html
On sa 210, when timer off (either from program or manually switched off) correct "bulb off" status is displayed on the indicator, but the power doesn't go off from the outlets. this problem...
Most digital timers can be restored by resetting timer and then reprogramming.
http://waterheatertimer.org/Sylvania-timers-and-manuals.html
http://waterheatertimer.org/pdf/Sylvania-SA-210-Manual.pdf
Sylvania tech support: 888-548-4484
www.hardwareinnovations.com
Sylvania timer has 1 year limited warranty.
Sylvania timer can be used for 1000W incandescent Loads and Motor loads up to 1/4Hp
All outdoor timers are susceptible to power surge from nearby lightning.
Timers are also affected by line noise and incorrect outlet polarity.
Test outlet with circuit analyzer. Use timer to control different Load on different outlet.
If more than one timer has same problem, then suspect can be line noise and outlet polarity.
Heavier-duty Intermatic HB8800RCL timer has limited lifetime warranty, and controls 1800 watts and 1/3 HP.
http://www.amazon.com/Intermatic-HB800RCL-Seven-Outdoor-Digital/dp/B001KBZUNK/ref=pd_cp_hi_2
Cant set my sylvania outdoor timer, says hit zip set and enter zipcode.i can only get 3 numbers in
Open following link for Sylvania timers.
3 numbers is correct.
77482 and 77468 will be inside same time zone.
So set 3 digits 774 and timer knows where you are astronomically.
The timer does not need your full mailing address zip.
Press red reset button.
Press mode button until ZIP icon displays.
Depress and HOLD clear zip-set button until display flashes.
Set first 3 area code numbers.
If zip set is not working correctly, then timer is defective.
Add a comment for more free help
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
The lights that are attached to my sylvania digital wall switch timer SA170 flash. I changed the batteries in the switch a month ago.
If timer worked correctly in the past, and suddenly stopped working, then manual says to push the reset button.
Following link has manual.
http://waterheatertimer.org/pdf/Sylvania-SA-170-Manual.pdf
I test timers, and most in-wall, and plug-in timers have 1 year limited warranty, although some last 5-7 years. When timers go bad, they are replaced. Sylvania is a good brand.
Add a comment for more free help.
1helpful
2answers
SYLVANIA DIGITAL WALL SWITCH TIMER SA 170. NO DIRECTIONS AS TO HOW TO PROGRAM THIS DEVICE. WANT TO TO BE ABLE TO SET SPECIFICI TIME FOR OUTSIDE EAVE LIGHTS TO COME ON AND GO OFF.
Manual at Hardware Innovations Click manual link to right of product photo
Sylvania SA170 manual shows that timer can automatically turn on lights at sunset time, just enter your phone area code: Timer has to wired first and power on. Manual has long list of instructions starting on page 2.
How to wire timer:
SA170 replaces on-off wall switch that has 2 wires + ground
Timer has 3 wires + no ground wire
Wires that come off switch connect to Timer Blue & Black wires
Timer white wire connects with other white wires in box - if you do not have other white wires, connect to bare ground
If timer doesn't work, switch Blue and Black wires
Top Sylvania Hardware & Accessories Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Sylvania Hardware and Accessory Expert? Answer questions, earn points and help others
