Sewing Machines Logo
D
Diane Servay Posted on Dec 04, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Kenmore 159.18131 that is bound up. The hand wheel will not turn. I am looking for a service manual. Does anyone know where I can find one?
Terry
Level 3:
  • Kenmore Master 11,377 Answers
  • Posted on Dec 04, 2019
Terry
Kenmore Master
Level 3:
Answers
11377
Questions
Helped
4626271
Points
152765
Po
ssibly for sale, but unsure if this is for that model. You seem to have repeated a question previously unanswered on FIXYA. Is that the correct model number for your Kenmore sewing machine?
http://www.kenmoresewingmanuals.com/kenmore_sewing_machine_service_manuals/kenmore_sewing_machine_service_manuals.htm
1helpful
How to get brother pr600 out of main motor test mode?
Looks like the machine is bound up, or the motor is failing. If the hand wheel is easy to turn then it is probably the motor drawing too much current.
Brother recommends a new motor and belt every 1500 hours of run time.
Kenmore 1774
My sewing expert (spouse) says you may have thread caught in the bobbin area. Remove all the thread from the top, they look inside, you may find the problem.
Be blessed.
Kenmore model # 11607090 older model, been setting up for several years, but has never been used-cannot unlock the hand wheel. we were able to wind bobbin, but wheel will not turn.
as for the hand wheel not not being able to turn, it's possible that something could be loose or broken
you said it's been sitting for several years,, I would suggest that the machine needs to be serviced
by a sewing machine repair shop, where they can check the handwheel & find out why it won't unlock, & that the gears & inside the machine can be checked & grease & oiled & the timing check also
Kenmore sewing machine Model 1602: I was filling a bobbin and when I went back to sewing - the needle won't go up and down. Motor runs when I press on the footpad. It is as if the clutch is stuck as well...
Sound like you need to take it out of bobbin winder mode. Suggest looking for a way to engage the clutch. Turn the center knob on hand wheel and or move the bobbin winding post back to postion.
The center hand wheel should move about 1/3 turn towards you to look it back into place.
3helpful
Hand wheel wont turn on my Kenmore sewing machine
it sounds like the belt to turn the wheel broke
How do I thread the bobbin in a kenmore 17628
you shoul check your manual.
If you don't have one,
I'am not sure what this machine looks like,
On the top part of the machine, put your thread on the thread spool,(on the right) the thread should be brought over to the left side and wraped around a small button looking piece. then brought back towards the spool of thread, bring the thread through a small hole in the bobbin, pul 2-3inch out, place the bobbin on the small metal bobbin holder and push to the right,
make sure pressure foot is up. you will need to loosen the hand wheel, hold the hand wheel with the left and and with the right hand turn the center circle back to it loosend (counter clockwise)
make sure the bobbin wind evenly
1helpful
2answers
Im trying to sell a Kenmore 117 - 959 but I can't get it to move. There is power to the work light, but Im stuck. Help!
If your gaskets are bad, the machine will not rotate. Can you move it by hand? If not then have you checked the gasket in the back of machine that comes in contact with the hand wheel? If it is making contact, this is what runs the machine and both the little black gasket and the hand wheel will spin when you rotate by hand. If the hand wheel is free spinning then it may need oiled. If you have a manual, try oiling the complete machine according to manual.
Top Kenmore Sewing Machines Experts
ZJ Limited
ZJ Limited
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
