SOURCE: Dremel 395 won't turn on
I have a Dremel 395 Type 3. Motor works fine, shaft doesn't turn. Took it apart to find that the white plastic or nylon flex coupling on the shaft had crumbled and the spline driver, which fits directly over the motor end of the shaft was somewhat worn. I emailed Dremel and got an overnight reply listing the 2 parts I need and the cost: Coupling is $1.00 and the driver is $1.25. Placed order by phone: 1-800-437-3635. I ordered 2 of each in case future replacement is needed. Total bill came to $7.27 including Florida tax and shipping. Can't beat that. They said it would be in the mail by tonight. (Flex coupling number is 2615294309; spline driver is 2615294308.)
SOURCE: two left red lights
The two red lights is usually over heating. Make sure it has good ventilation and that the fan is working in the back. Let it cool down for a couple hours and try it again
SOURCE: screen stays black on startup of toshiba satellite L300
have you tried either switching between external and internal monitor usally Fn + F5 on toshiba or try plugging a monitor into the back and see if it displays.
if you get a display on the external monitor then its probably a screen or inverter fault if you donot get a display to an external screen then it is likley t be the graphics on the board itself.
hope this helps
SOURCE: Geovision play back has blank blue screen every
I have the same problem and I'm looking right now the answer. I think that windows 64bits its the problem
SOURCE: Won't get past the Nokia Screen upon start up
i suppose the phone has been by attacked by a virus. if you have entered unsecured sites or connected to an unprotected computer, this might happn. please take it to the nearest nokia customer care center to get it done.
