Question about Invacare Health & Beauty
My invacare tdx so goes to left break fault just trying to go out the door. I,can reset it and power up. However I,keep,getting left break fsult going over threahold of door. Ive had it since August.
    Master:
  • 811 Answers
Sounds like a loose/broken wire if it takes a jarring to cause the problem. a careful inspection of the wires and connectors might be helpful.
Posted on Dec 04, 2019
6ya staff
SOURCE:
mel160120
  • 7 Answers
SOURCE: alarm keeps going off when I open the drivers door
Make sure you unlock your door with the remote before getting in. Often times, they are automatically armed.
Posted on Feb 10, 2010
Neil Wood
  • 177 Answers
SOURCE: invacare auriga looses power
Hi. Most probably its the throttle pot ( Wig Wag ) thats causing the problem. I am an Invacare service agent and I have changed these many times for this very reason.Also check motor brushes are not worn down or jaming. Good luck. Neil.
Posted on May 30, 2010
wcdoc1953
wcdoc1953
  • 280 Answers
SOURCE: INVACARE STORM TDX DROVE OFF OF CURB LOST POWER
Sounds like your battery or batteries became disconnected. Remove the 3 screws holding the rear electronics cover on the chair. Check all the controller connections and specifically the 2 pin plug into the batteries in the battery box. Remove the screws and pull the front battery box cover off. Slide out the battery tray after removing the retaining screws on the bottom sides at the front. Check the batteries for loose or damaged connections and tighten.
If you cut or broke wires at the rear or bottom of the controller you can do a temporary repair and order new parts. You should be able to get the chair to power up if the power path connections are good. If it powers up after a check of the battery connections and power connection to the controller and you still have a fault code, I can help you further. Hope this helps you for now.
Posted on Dec 11, 2010
Kevin Rivas
  • 63 Answers
SOURCE: The power funtion drive on
1) Yes your power seat functions can be programed into your drive 4,You'll need a programmer or have to take it into a shop.
2) yes the chair can be manually elevated down,You'll want to take it to a shop for that ,because it requires jumping the power to the seat elevator and swapping the wires around and I would never recommend my customers to do such a thing because of electric shock or burning up the chair.
If your chair has a four wat toggle switch("what controls your power seat functions elev,recl,telt,ext) If thats what your using right now there may be a red light that comes on in drive lock out ,If that light is not on follow that wire all the way down it may have been pinched or cut.If so it will need to be replaced.
Problems like this one is hard to trouble shoot over text or phone ,if your four way switch cord is cut or smashed .Your gunna have to take it into a shop just to make sure ,It didnt cause any electrical problems in your chair .
Good luck hope i had the chair in front of me so i could help you more.
Posted on Jan 18, 2011
undernet01
Aaron Busch
  • 492 Answers
SOURCE: invacare m51 power chair controller
I'm in a power wheelchair myself. If the wire coming out of your controller has a place in which it can be unplugged, you can try unplugging that, then plugging it back in. If that doesn't work, then you probably don't have the appropriate tools needed to reset the controller. You'd need to take it in to get serviced.
Posted on May 03, 2011
Invacare tdx sp electric wheelchair runs fine but every time my husband stops and goes it makes an annoying clicking noise just when he is going forward or backward
That clicking is a electronic motor lock disengaging when you start and re-engaging when you stop. That is quite normal though some are louder than others. You cannot make it any quieter than it is.
Feb 06, 2018 | Invacare Health & Beauty
My invacare tdx sp keeps flashing 5 error code it left wheel lock what is common reason for 5 flash
hi, Normally means the brake is in freewheel mode, you need to move the lever so it's in Drive mode then turn the chair back on ..
Regards
Sep 20, 2017 | Invacare Health & Beauty
My Invacare TDX SP got stuck in hole in grass near a side walk. I tried repeatedly to free it by going forward and back.
The motor may have a build up of carbon dust which can short the motor. needs to be checked.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Mar 12, 2016 | Invacare Health & Beauty
Looking for reset button oN TDX SD power wheel chair
Hello, Invacare does not have Reset Buttons on the power for the batteries. They only use fuses. Now if the joystick has a display and it says to press a reset button and it did not used to say that then the programming has be lost or changed by the rain or battery power. You will need to have someone with an Invacare Programmer reprogram the chair or a reset switch can be purchased that will plug into the joystick and allow you to get pass the Press Reset command on the joystick.
Jun 14, 2015 | Drive Health & Beauty
Unlock handset
See if there is a yellow light blinking on the joystick as well. Count how many times the yellow light blinks between pauses and blinks again. When you have the number of time the yellow light blinks (between 1 and 9 times) look it up in the owners manual or repost it here to be answered.
Oct 15, 2014 | Invacare Health & Beauty
Invacare TDX SR
I live in Sonora, Ca. and am looking for a place to get my TDX SP chair fixed. It need some new leg rest that don't kill my legs 5 mins after I set down. Something on the back of my chair is broken where it attaches to my back plate. and a few more things. I tried a place in Modesto, CA and they stink!!! Over charged me, asked for the money upfront before my inc. had a chance to make good on it, and then it took them 6 full months to refund my money that was over the copay I have to pay with my blue cross inc. Please tell me a place I can get some work done, my chair cost over $6,000 and It has served me will, but I need to take care of it.
Jan 23, 2012 | Invacare Pronto M51 Power Wheelchair
INVACARE STORM TDX DROVE OFF OF CURB LOST POWER IMMEDIATELY
Dec 11, 2010 | Invacare Health & Beauty
Message on storm model tdx 3 joystick is ''E 15 M1 power stage faulty''
J I am not familiar enough with the TDX to give you an answer but you can contact Invacare Tech support @ 1-800-333-6900 ask for chair tech suport and explain your problem Hope this helps
Sep 27, 2010 | Invacare Health & Beauty
Stability locking kit
The M51 does not have a stability locking kit. The Invacare TDX SP has a gas strut stability locking kit that just had an extensive recall campaign associated with it. Please describe your issue in greater detail.
Jul 16, 2010 | Invacare Pronto M51 Power Wheelchair
Health & Beauty Logo
24 people viewed this question
Top Invacare Health & Beauty Experts
Rob Hill
Rob Hill
Vincent G
Vincent G
Andrew Taylor
Andrew Taylor
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
