Sinotec 55inch brand new tv 3 days no sound? changed hdmi/ checked all input/ output all correct Please help?
    Top Expert:
  • Televison & ... Master
  • 66,086 Answers
NO HELP FROM HERE CALL FOR WARRANTY HELP TO MANUFACTURER
Posted on Dec 08, 2019
6ya staff
SOURCE:
Anonymous
SOURCE: No video throught HDMI output
press set up go option number 1 then go hdmi monitor and input yes. then press set up again
Posted on Dec 11, 2007
Anonymous
SOURCE: Onkyo 605 HDMI Sound
Change the setup in the Hardware control/HDMI/ HDMI Audio...
Posted on Jan 26, 2008
Anonymous
  • 13 Answers
SOURCE: hdmi connection doesnt work on ps3
By you saying that you have a new cable & tv, I assume you had the console conected tru composite before (red, white & yellow rca cable). This is what you need to do: Connect the PS3 to the tv with HDMI cable only, do not use the composite cable at the same time, reset your PS3 by pressing and holding the power button, when the power is off, for about 7 to 10 secconds, it would cicle from power off, on, then off again, it would also give you 2 sets of beeps, after the power is off, turn your tv on, make sure you select HDMI input on it, then turn your PS3 on, the console would set itself to the best resolution available on your tv. Give it a try!
Posted on May 22, 2008
Anonymous
SOURCE: sa-dx1040 dvd optical input works, tv and cd do not.
You have to manually select digital input on the receiver.
Posted on Aug 30, 2008
Anonymous
  • 306 Answers
SOURCE: HDMI to DVI gives pink screen
Make sure the Geforce outputs in DVI-digital
then  Boot the PC while the TV is on and connected. This allows the card to read the EDID from the TV and provide the best resolution...
Most displays work best at their native resolution, which is either 1920 x 1080, 1280 x 720, or 1024 x 768 for most HD TVs. It sounds like your video card has difficulty handling resolutions that high and that may be your problem.
One has to remember that DVI/HDMI is capable of carrying two types of Colourspaces: RGB and YPrPb. Unless modified, the PC will always output RGB.
Do you any other components that use HDMI that you can test, or another HDMI port on your TV that you can use? If not, then the best you can do is swap the cable and contact your provider about the problem,  Make sure the Geforce outputs in DVI-digital
Do you any other components that use HDMI that you can test, or another HDMI port on your TV that you can use? If not, then the best you can do is swap the cable and contact your provider about the problem, as well as contact toshiba if swapping the cable and box doesn't resolve the color problem.
Posted on Oct 17, 2008
New cable box now no sound
* Brand, model for specific information.
* Check your warranty call for support.
*** Following is for information only.***
* Many times when hooking up new equip one must read the instructions as to the new configuration may be different with the older set up.
* As of Jan 2018, cable boxes have switched to all digital output.
* Outputs can be separate video and audio or combined as with the HDMI cables.
* Check your TV input set up to select the right cable input; HDMI-1, HDMI-2, COMP. Note; RF input may not be available in certain areas.
* The COMP input also needs an audio (in stereo) input from the cable box. It's usually a RCA plug (White and Red) The video will be 3 separate "colors" RCA plugs that needs to be matched to the correct input.
* You will also need to check your TV menu for the audio settings if it is set up for your current speakers set.
* Check with your cable provider for additional support.
Aloha, ukeboy57
Aug 27, 2018 | Televison & Video
How do I connect my receiver so that the sound comes from my speakers????
Please read the manual. You should connect speakers to the speaker output of the receiver, or amplifier. You connect the TV with a receiver through a HDMI cable. Depending what would be the source from that you take the output and the place the signal is going to there you should use the input. Don't connect anything without 100% certainty it is correct. You could damage the whole equipment when connected the wrong way around.
Dec 28, 2014 | Samsung 50" Uhd 4K Smart Hdtv
Pc input no sound through screen. but sound when changed to hdmi input?
If you are feeding video from your pc to your TV from the pc video card, then no audio will go to the tv unless that is connected also from your pc audio output.
HDMI (Multimedia Interface) means it connect both mediums: i.e.audio and video.
May 06, 2012 | Televison & Video
Unable to get TV sound and dvd sound through the surround sound speakers with samsung compatible tv and blu ray player
Hi,Even though you have not mentioned about the cabling connections you have done, for the sake of correct connection I describe all the possible cabling alternatives to you..You can select whichever you want..
TO WATCH DVD ON THE TV:
** Receiver's "AUDIO and VIDEO OUTPUT as " 2xRCA Audio+1x Video " or "Optic Cable OUTPUT or " HDMI Output " of your Home Theater Receiver (whichever you want ,based on the existing sockets and necessary cables on your hand )
** AT TV side : you need to connect "Audio+ Video input s " as can either be : 3xRCA jacks or "Optic cable input " or HDMI IN connector of your TV ,
** than just switch to DVD mode on Receiver and play DVD
You can use "HDMI" connections as well but sometimes HDMI creates problem on Audio..
TO LISTEN YOUR TV ON SURROUND SYS.
** AT TV side : you need to connect "Audio Output " as can either be : 2xRCA jacks or "Optic cable output" or HDMI connector of your TV ,
** to Receiver's "TV input "or "AUX input" or "Optic Cable input"
or HDMI of your Home Theater Receiver (whichever you want ,based on the existing sockets and necessary
** than just switch to respective SOURCE mode on
Receiver corresponding the connector you have used on the back of Receiver ..
Pls remember.."IN " goes to "OUT" or vice versa..all the times..
There you go..Both Tv and DVD sound are on the
Receiver as SURROUNDING SOUND .By this means ,whatever you watch on the TV will come thru your Receiver's SURROUNDING SOUND speakers as well .
Hope this helps!..if more help requires pls let me know.
Take care
Aug 17, 2011 | Televison & Video
Blue ray is hooked up to tv with HDMI correctly but there is no sound when playing the DVD
Check the hdmi port on you tv. There are some tv's that have an HDMI port that say HDMI/DVI(its a port for an older Digital Video that required seperate cable for sound), if this is the case then you need to hook it up to a different HDMI port on the tv because that input does not carry sound(you will see red and white audio inputs next to it) or use the audio outputs(red and white) cables and plug them into the out put of DVD player to the audio inputs that correspond to that same HDMI input. If this helps please rate me I do not get paid in anyway. I like to help people and want to make sure this is helping.
Dec 17, 2010 | Samsung Televison & Video
Sony Viao HDMI to Panasonic Plasma TV HDMI Input handshake
Try all of your HDMI inputs, one may be rated at the correct voltage to be able to display the video. The offical part that Panasonic was giving for this was PDPHDMIKIT, its basically a HDMI extender that regulates the voltage. The part is still available online, try partstore.com or andrews-electronics.
Apr 23, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
JVC LCD TV (LT-42X688) input panel not working!
1. This TV has setting for the HDMI input that allows you to select the HDMI Audio or Analog(red/white wire) audio. Make sure this is correct
2. Most cable boxes are DVI not HDMI. If DVI then you actually do need to use those Red/white cables. If HDMI, refer back to #1.
3. The cable box has a setting to select the Audio output, HDMI (digital) or Analog(red/white cables). Just like #1, this has to be set.
4. Contact your cable company to help you set up the box correctly. JVC can probably help you check the TV
Mar 05, 2009 | JVC LT-42X688 42 in. LCD HDTV
HDMI Output with my Onkyo 875 Receiver
Hello, the TX-SR875 does not support up-converting from component or S-video to HDMI. Is the model number correct? You stated the receiver is "brand new". This model is from 2007. Thank you, Onkyo USA
Mar 23, 2017 | Onkyo TX-SR875 Receiver
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
