SOURCE: my gigabeat f60/f20 sytem error
Your hardrive maybe faulty is it clicking??? otherwise format it and reinstall the software.
Here:
http://www.megaupload.com/?d=GTC188NU
SOURCE: i brought a hp laptop
> I return it back to the dealer.
Did they replace the fan, or did they replace the computer?
> they told me to contact HP for further repairs.
Did you do so? If so, how did HP respond?
The purchase of the computer includes a one-year warranty,
i.e., HP will fix anything that fails, within one-year of purchase,
at *THEIR* cost.
SOURCE: my system operating fan 90B
If you are having problems with the cooling fan the best solution is to replace it. Fans are very difficult to actually fix unless you know how to replace the copper coils which are used to create the magnetic force used to turn the fan mechanism.
SOURCE: system fan 90b not working
Check for dust build up. If non then the fan needs to be replaced.
SOURCE: system 90b error
Run the Check Disk Utility
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.If check disk fails to fix it, then you will need to reinstall your operating system. Do a Repair Install so that you don't lose your data.
