Make sure ground and power to the AMP are perfect (clean and tight). Afterwards unplug all the speaker wires and/or RCA speaker connections. Does the light still flash and power down after it is reset? If so, the AMP may be damaged. If not, then one of your speaker wires are shorted. Plug one speaker in at a time. One of them should cause a negative reaction.
SOURCE: kenwood kac 859 amp
The amp will reset every time it's turned off. The red light flashing, instead of staying constant is a warning that one of the protection circuits are activated. If the amp is bridged wrong, it can do this. If the load impedance is too low, it can also do this... don't trust the speaker, it it says 4-ohm, it may actually be 3.8-ohm, which could cause a problem if two speakers are wired in parallel. If it's not getting enough power, it will turn off briefly, but will turn back on after a second. A capacitor is not necessary with this, just use 4 gauge cable and have a good battery... make sure the ground is good, that one is commonly ignored.
SOURCE: Kenwood Excelon KAC-X521
According to page 7 of the radio's manual, E-02 means the amp has failed and DC is being applied to the speakers. It also says "Turn the POWER switch "OFF" and release the protection."
SOURCE: Kenwood eXcelon KAC-X810D
On the top of the amplifier are 4 controls. The first one is labeled as "input sensitivity". That is the adjustment you need to make. It would need to be set at around mid way between minimum and maximum.
One way for you to set it perfectly for your speaker would be to have it set first at about 1/4th of maximum, and then with the volume of the head unit turned all the way up with some heavy bass playing start to turn the input sensitivity up very slowly until you hear a small amount of distortion or rattling from the sub woofer. At that point you would back it down just a touch until there is no distortion or rattling from the speaker. This would have your amplifier set at a point where it is not pushing the speaker too hard but you would be getting the most from it.
Remember that any time you hear distortion, you are either pushing the speaker too hard or the amp too hard. The distortion is caused by clipping, which is not a good thing. If there is no clipping from the amp, and no abnormal sound from the speaker, you have it set properly to get the most from both the amp and the speaker and you are then minimizing the chance of damaging either the amp or the speaker.
Very wise decision on your part to want to use your equipment properly and not expect more than it is actually capable of. Many people just push their equipment to the max and then complain about how it broke down on them. If you follow my instructions you should be able to keep your sub woofer and amplifier in good working condition for as long as possible. It is no guarantee that it will never break down on you, but you will at least give it it's best chance for longevity.
SOURCE: Kenwood KAC-8103D Power Amplifier wont turn on
it sounds to me like its burnt.but with some amps the screws that hold it in place have to be screwed into the car chassisfor grounding. be careful not to srewe into hidden wires.
