Question about The Health & Beauty
My 1113 ats jazzy controller will not come on. Charged the batteries and still not working. Unplugged the cable to the controller and plugged it back in and could hear it beep but still won't light up. Please help
    Top Expert:
  • The Master
  • 66,497 Answers
Buy a can of contact cleaner and start thru the system , cleaning any and all connections . also any and all grounds .
Posted on Dec 20, 2019
5 Suggested Answers
mohammed387
mohammed marika thambi
  • 1952 Answers
SOURCE: jazzy 1113
check wiring and pcb in your chair...it may be loose connection in between the path
Posted on Sep 30, 2008
Anonymous
  • 38 Answers
SOURCE: We have a Jazzy 1113
The battery of the chair is dead. It will say its charged but then when you take it off it will die.
You have to replace the battery.
I had the same exact problem with my father.
Posted on Dec 30, 2008
Anonymous
  • 40 Answers
SOURCE: My Jazzy won't move.
If your batteries are truly charge they should read around 24.5 VDC. And if the freewheel lever is engaged and you still have no movement your probably need to get into a service tech. Also check the circuit breaker on the chair.
Posted on Apr 03, 2009
douglass smith
SOURCE: I have a Jazzy 1113 powerchair and the on board
my chair jazzy 1113 ats won't move.all the lights are flashing and the batteries are fully charged why are they flasng
Posted on Apr 28, 2011
Louis Smith
  • 104 Answers
SOURCE: Jazzy 1113 Power wheelchair. Batteries are fully
I'd look for a loose connection, one battery bad could be it, but its not likely, you can still move it with low voltage, one low batt., could be joystick. You can get generic trouble codes off your joystick, and call the manufacturer, Pride, 1-800-800-8586.
Posted on Jul 10, 2012
Jazzy 1113 ats fully charged will not move
Check the controller connections and the circuit breaker.
Oct 23, 2013 | Pride Jazzy 1113 Power Chair
Jazzy 1113 power chair shows charged but control light is blicking. Chair will not move.
It appears that the controls are in Lock Mode. Unlocking Instructions depend on your type of controller. Go to PrideMobility.com to download the proper manuals for chair and controller.
Feb 11, 2013 | Pride Jazzy 1113 Power Chair
The jazzy 1113 will not start, when you press the power button the speed light comes on gets full and then turns back off
How old are the batteries? If you've had them for a few years it might be time to change them. Even if batteries are charged correctly they eventually lose power with use and need to be changed. Here is a link to the battery needed for the Jazzy 1113 http://www.replacementupsbattery.com/UB12350-NB.html
Nov 08, 2010 | Pride Jazzy 1113 ATS Indoor Power...
I have a 1992 jazzy 1113 ats wheelchair and i accidently locked it the other problem is that the only way i can get the controller on is to plug it into the onboard charger and then a green light and a red...
Aimeelynn I'm e-mailing you the unlock procedure for a VSI controller. If thats not what you have you can e-mail me back the type of controller you have. I will also try to answer the other questions you have
Nov 07, 2010 | Pride Jazzy 1113 ATS Indoor Power...
Jazzy 1113 ats won't start
Nov 04, 2010 | Pride Jazzy 1113 Power Chair
Jazzy 1113 ATS Indoor Power Wheelchair: the battery is fully charged but it wont move does...
Hi. Your machine probably has a fault, but I very much doubt that it needs reprogramming.
Are the free-wheel levers in the correct place? Is the machine displaying any fault codes, e.g. flashing LED's and what is the pattern or number of flashes between pauses?
Good luck. Neil.
May 16, 2010 | Pride Jazzy 1113 ATS Indoor Power...
We have a Jazzy 1113 Power Chair. The chair is fully charged, but does not move. What might be the problem?
Dec 30, 2008 | Pride Jazzy 1113 ATS Indoor Power...
Health & Beauty Logo
Top The Health & Beauty Experts
widgid
Level 1 Expert
Marc Taylor
Are you a The Health and Beauty Expert? Answer questions, earn points and help others
