t's possible that the 5-year-old accidentally changed the input source on the Samsung TV, which is why you can't get the Fire Stick to work. Here are the steps you can follow to switch the input source back to the HDMI port where your Fire Stick is connected:
Turn on your Samsung TV and your Amazon Fire Stick.
Using your Samsung remote, press the "Input" button.
A list of input sources should appear on your screen. Use the arrow keys on your remote to select the HDMI port where your Fire Stick is connected. The HDMI port may be labeled as "HDMI 1," "HDMI 2," or something similar.
Press the "Enter" or "OK" button on your remote to select the HDMI input source.
Your TV should now switch to the HDMI input where your Fire Stick is connected, and you should see the Fire Stick's home screen on your TV.
If you're still having trouble, try unplugging the Fire Stick and plugging it back in to make sure it's properly connected. Also, make sure the TV and Fire Stick are both updated to their latest software versions.
Restart the device: Settings > System > Restart, then once restarted unplug the power cable for 5 seconds then plug back in. I hope this helps you and hopefully fixes your Fire TV issues. Press the Menu + Left (directional key) + Back buttons at once for 10 seconds. These are the steps for factory resetting of remote.
Could not find a Polaroid TB301, so we'll have to guess.
Press the Menu button on the remote and use the right and left arrows to select AUDIO.
In the AUDIO Menu, use the up and down arrows to select SPDIF Type.
If the sound bar is connected to the TVs Digital Audio Out, (it plugs into the socket with the red light) select Dolby Digital.
If the sound bar is connected to the TVs R/L Audio Out, select PCM.
1,Before you pair an Amazon Fire TV Remote or Amazon Fire TV Voice Remote, verify that the remote is compatible with Amazon Fire TV, is within range, and has the required batteries installed. 1. From the Home screen, select Settings, and then select Controllers. 2. Select Amazon Fire TV Remotes, and then select Add New Remote. 3. Press and hold the Home button on your remote for five seconds. Fire TV Stick searches for the wireless signal of the remote. After the remote or game controller is discovered, select it from the list of discovered devices using your already paired, existing remote or game controller.
