SOURCE: instruction manual for older style corded GE speaker phone
Here are the quick instructions on how to program the phone numbers.
You can also download a copy of the User's Guide from: http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=c96e9c823d0df43989039e5385bef04a&q=GE+29322GE1
Just enter the 4 digit captcha code and you will be able to download the User's Guide.
Please let me know if yo have any questions.
Good Luck!
STORING A NUMBER IN MEMORY
To program priority keys:
1. Make sure the telephone is properly installed. Pick up the
handset and listen for the dial tone. If you don’t hear the
dial tone, recheck or repeat the installation steps.
2. Press the SPEAKER button or pick up the handset.
3. Press the store button.
4. Dial the number to be stored.
5. Press the store button again.
6. Press the A, B or C button.
7. Press the SPEAKER button or hang up the handset.
To program frequently called numbers:
1. Press the SPEAKER button or pick up the handset.
2. Press the store button.
3. Dial the number to be stored.
4. Press the store button again.
5. Press one of the 10 memory location buttons 0-9.
6. Press the SPEAKER button or hang up the handset.
SOURCE: Trying to find instruction manual for AT&T Lucent 822 2 line speaker phone
Use the 922 manual. It's almost identical.
SOURCE: Need to re-pair bluetooth to phone
Go to ur phones bluetooth settings - activate pair new device - at the same time press and hold the on button on your blue tooth head set for about 10-15 seconds - this will enter the device into pair mode - on your phone - click on pair with new device etc etc, the default access code is either 0000 or 1234
SOURCE: can not pair with my new Blackberry storm - Help???
Make sure the BlueAnt Supertooth 3 is turned OFF.
When your blackberry ask your permission to allow bluetooth to connect and donload phonebook allow it permanently.
SOURCE: Need to know how to pair a wireless gear
press and hold the third button with the phone picture on it continuously until the light displays red/blue alternate blinking light (not just blue flashing, if you see blue flashing and no red, you didn't hold it long enough). Once that is going then turn on your phone's blue tooth setting to be 'on'. At that time the phone should see the bluetooth and try to pair. It will ask you for a pin (your phone will) the pin is 0000. Hope this works for you, prob depends on which model you have, I have wireless gear bluetooth, with 3 buttons across it, and the base of the unit is black.
