SOURCE: maytag ice maker flap keeps opening like it was possessed
If the flap your mentioning is the one that opens and closes that is on the freezer door,than it needs to be replaced with the "Fountain Kit ".In this kit you will have the parts that control this problem.Replace ALL the parts that are in this kit with the parts off your old one.If installed correctly ,the problem is fixed.
SOURCE: want ice maker with crushed ice maytag
Try looking in your phonebook for Servall. It is a reputable appliance parts source. Or if you can check online for the Maytag website you can usually find the part yourself and order it or talk to customer service. Last, there are a number of online appliance parts companies which may sell genericparts for your unit.
SOURCE: Water wont fill ice maker
the relay is the ice maker , buy the kit that contains the valve and it is a complete new ice maker system.
easy to find at sears parts.
Phil
SOURCE: Maytag Ice Maker do not work
No your model has a module that if defective you will need to replace part number D7824706Q But we are not sure yet so I want you to fill with tap water and turnon and if the the ice freezes and dumps normally into ice bin then it is possible that the water control valve for ice maker side is defective. please try that first and let me know, Thanks, Sea breeze
Testimonial: "Thank for your help. Very specific and ilustrative your explanation."
SOURCE: maytag refrigerator ice maker opens and closes?
replace the icemaker you can order one directly from marcone or allbrandsppliance
