Sewing Machines Logo
Tammy Hord Posted on Dec 24, 2019
Can I use a Janome darning needle on my elna 6200?
ARTURO AGUILAR
Level 1:
  • Contributor 4 Answers
  • Posted on Aug 02, 2020
ARTURO AGUILAR
Contributor
Level 1:
Answers
Questions
0
Helped
1258
Points
5
If your using your standard universal needle, you can. just make sure your using the right number for the material
2answers
Can I do free motion quilting on an Elna Carina SU
i don't know of any machines that can't free motion quilt. you will need to either drop the feed dogs or buy an attachment to cover them, then buy a quilting foot that fits your machine .
1helpful
Quilting with Excel 5018 can I do free motion quilting
Yes, you can do free motion sewing and quilting with the Janome Decor Excel 5018. Look on the back of the sewing machine behind the needle and bobbin case section. At the bottom of the free-arm section of the machine, more or less in line with the needle bar, is the feed dog position switch. Move the switch towards the motor of the sewing machine to lower the feed dogs. Move it away from the motor to raise the feed dogs. For pictures, see the manual for the Janome Excel 5018, available from Janome here: https://www.janome.com/siteassets/support/manuals/retired/other-models/inst-book-5018-ennose.pdf . Look at page 2 (item 22), page 6 and page 22. (These are pages 8, 16 and 48 of the PDF.) This is a retired machine for Janome and the manual is listed among those here: https://www.janome.com/support/retired-machine-manuals/ .
I hope this helps. Note: you will have to adjust the tension carefully before starting your quilting.The darning foot, https://www.sewingpartsonline.com/janome-darning-foot-200349000.aspx , will help you see where you are sewing better than any of the included accessory presser feet.
2answers
Can feed dogs on janome 1600 series be dropped
No the feed dogs aren't dropped on the Janome 1600 series sewing machines. Instead, you cover them with the darning plate. I haven't found the darning plate sold separately. https://www.sewingmachinesplus.com/jan-767-827-009.php is a source for the darning foot and darning plate. As far as I can tell, the darning plate is not among the original accessories for any of the Janome 1600 models. The manuals for two of the Janome 1600 models are on the retired machine page: https://www.janome.com/support/retired-machine-manuals/ . The manual for the Janome 1600P-QC is on that machine page: https://www.janome.com/machines/sewing/1600p-qc/ . The direct link to this manual is https://www.janome.com/siteassets/support/manuals/professional-series/inst-book-1600pqc.pdf .
I hope this helps.
1helpful
How do I drop feed dogs on jem silver 662?
Here's a manual:
Instruction Manual Janome Jem Silver 662
The following is for a 660, but it doesn't mention anything about darning or free motion quilting:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&ved=0ahUKEwih_NGBzpjRAhXKh1QKHbKIAvwQFggoMAI&url=http%3A%2F%2Fjanome.com%2Fsiteassets%2Fsupport%2Fmanuals%2Fcompact-models%2Finst-book-jem-gold-660.pdf&usg=AFQjCNEwCPZs5n8s4wdgIHMGHbN-GvDe-w
You can also contact a Janome dealer. If the machine does not drop the feed dogs, there should be a special plate accessory to cover them in order to do darning or free motion quilting.
Perhaps this is the accessory you need:
http://www.sewingpartsonline.com/cover-plate-elna-janome-necchi-825018035.aspx
https://tv-sewingcenter.com/products/janome-quilting-attachment-kit-for-jem-series
How do you drop the feed dogs on an elna su?
I think you need a needle plate cover, also called a darning plate. It fits over the needle plate effectively dropping the feed dogs.
Elna 683 overlocker spare parts
I can see a needle plate
http://www.sewingpartsonline.com/needle-plate-janome-788601007.aspx
from sewingpartsonline.com, but it is marked as being for Elna 664. They don't have your model listed on their website.
You could email them and ask if its compatible with your model or just look at the part and see if it looks the same to you?
Other option is to contact Elna head Office in your country and ask them for price and availability; often this is best course of action as any sewing machine dealer will probably need to order in the part anyway.
Visit www.elna.com, then go to your country, then "Contact Us" page to find their contact details.
Hope this helps you get the overlocker going again.
1helpful
How can i replace the threader, mine seems to be broken. When I want to thread it does not catch on the needle.
Perhaps the little hook has been damaged on the end?
I have seen this part
http://www.sewingpartsonline.com/needle-threader-elna-janome-new-home-755643002.aspx
listed for sale - it doesn't list your model but it looks very similar to the threader on my Janome MC6500.
Needle thread tension- huge loops
Put the tension settings back to the mfg's suggested setting.
Re-thread the machine with the presser foot up and there will be no more loops.
Solving thread breaking
the solution is above I damaged the darning hook and plate by not using the correct needles
2answers
Embellishine machine
To my knowledge this is requires a special machine, a felting machine. Brother, Janome, Babylock sell models
Top Janome Sewing Machines Experts
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
