1. Take off the Bluetooth headset and move the ear hook to the closed position. This is the method used to turn off many Bluetooth headsets and if that is the method used by your headset, it will now turn off. If it stays on, continue to step two.
2. Look on the sides of the Bluetooth headset for an "On/Off" switch. If it has such a switch, it will currently be at the "On" position. Move the switch to the "Off" position. If your Bluetooth headset doesn't have a On/Off switch, continue to step three.
3. Press and hold the main button on the Bluetooth headset for several seconds. After a few seconds an LED light will start blinking on and off and your Bluetooth headset will turn off momentarily. If it still doesn't turn off, consult your Bluetooth headset manual for model-specific instructions.
If you can't turn off your wireless earbuds through the ways above, your earbuds may be broken. You can select a new one from: Best TWS Wireless Earbuds
Press and hold the MFB buttons for about 5 seconds to turn them off. When both earbuds are paired with your cellphone, press and hold the MFB button on either left or right earbud, the other earbuds should turn off at then at the same time.
