Step To Fix Epson Printer Error Code 0x97
Apparently, it generally occurs on models: Epson wf-3640, wf-4630, wf-3620, wf-7620, and 7610. If you want to resolve the Epson Printer Error Code 0x97 then you can follow the below steps:
Method 1# Unplug and Plug-in:
1. First of all, you have to unplug all the connected cables on your printer.
2. Now take all printer cartridges to remove from your printer.
3. Still turned off your printer from the power source by pushing down the power cables.
4. After that, plug in all the cables and then USB cables.
5. Reinstall the ink cartridges on the printer.
6. Now turn the power back on and then check if the error code still appears.
7. Check whether the blunder message remains. In the event that the error persists, proceed to the next method.
Method 2# Other Method of Unplug and Plug-in:
1. Switch off your Epson printer and then unplug it from the power source.
2. Disconnect the connected cables and USB devices.
3. Now, wait for about five minutes until the printer takes a rest.
4. Push and hold the power button on your printer for fewer minutes.
5. Now you have to connect the power cord to your printer and then release the power button.
6. After that, check whether this message still appears or not.
Method 3# Clean Clogged the Printer Nozzles:
1. Turn off your printer and then unplug it from the power source along to your Computer.
2. Now open the printer casing carefully.
Now take a clean paper towel and then it with any head cleaning fluid.
3. After that, make the soaked paper towel position down into the middle of the printer heads.
4. Now sit it for 12 hours and then check if the error code doesn't reappear.
Method 4# Try Microsoft's Printer Troubleshooter:
Microsoft proffers plenty of troubleshooting tools for printers and you can use any one as per your printer and issue facing with the printer. You can download it from the official website of Microsoft as per your printer model and computer's OS. After that, run it on your computer to fix the multiple issues including the Epson printer error code 0x97 error in a very effective way.
Method 5# Turn On and Off Your Printer:
Sometimes turning a printer on and off may fix several technical issues including the error code 0x97. You can perform this process in the below manner:
1. First of all, unplug all the cables and USB accessories from your printer.
2. Now press and hold the power button from your printer for about 60 seconds. It will allow taking reset your printer.
3. Now plug back all the accessories.
4. After that, again press and hold the power button for 60 seconds and then run a test print.
Method 6# Disconnect and Reconnect the Printer:
1. Check for any paper jam if available and then wipe it out.
2. Unplug all the cables and USB connection to your printer.
Press and hold the power button for about fewer seconds and then release it.
3. Now wait for about 1 minute and then plug the accessories back into your printer.
4. Now turn on your printer and then take a run test.
By following the above-described methods, Epson printer error code 0x97 can be fixed in a very simple manner. If you need any assistance, then contact our Epson Printer customer support team. They will provide you the best solutions to fix all issues related to the Epson Printer.
There does not appear to be a single solution that always fixes this error message. For some users, procedures for cleaning the nozzles works. For others, switching the particular software program you are attempting to print with works. For a considerable number, contacting epson about your warranty (a year) yields a replacement printer being shipped. The approach from Epson for tackling this problem appears to be powering the printer off, detaching peripherals, reseating cartridges, waiting 5 minutes, an re-powering. Here is a link offering variations of this: https://tonixcomp.net/epson-error-code-0x97/
Which ever fix is employed, the ones which do NOT work include replacement of drivers, scanning for viruses, and firmware updates. Hope this saves you some time. I also note that this error message is not confined to a single epson model but it is generally a good thing to supply that model number as well as your OS when researching a problem.
SOURCE: Epson WF-3640
Apparently cleaning with a wet towel or wet wipe is needed.
Don't be tricked into downloading antivirus software from some web sites that are actually malicious.
Example of cleaning suggestions:
https://answers.microsoft.com/en-us/windows/forum/windows8_1-performance/my-epson-wf-4630-pro-printer-led-screen-error-code/9d577dff-75a0-4885-a10e-cf948f3f491e
"Before you buy a new one. Clean the rolls and ink holder in the printer with a wet wipe or wet cloth. Start it without the ink cart, it should then ask you to insert it. Insert it then and it will go through the new ink routine. I did that twice and it fix the error.
It seem like one of the nozzle might be clog up and clean and forcing the printer to push more ink out will clear the clog."
