I have Lupus and drink turmeric and ginger for the pain which helps a lot. Now I have a blood clot in my lungs and am on Coumadin.
SOURCE: oasis drinkingfountain - Why would fan run continually? Cools wel
The fan and compressor run at the same time.
Both get power from the on/off cold control termostat.
1.Defective thermostat.
2.Compressor not cooling.
If the water is chilling go to #1.
SOURCE: stomach pain drinking from refrigerator water dispenser
Get a charcoal filter from home depot (about 50.00) and install behind refrig or in cabinet . Filter has replaceable cartridges like for charcoal , lime , calcium . Installs in supply line to refridg . Do not recommend the 11.00 filter installed in line , where you replace the whole filter . Get the replaceable cartridge type .
SOURCE: drink o matic problems. help!!!!!
Ok here is the poop. I just tore mine apart the green light did not come on and the fan did not work. I looked at the circuit board I don’t know how many times before and missed a covered fuse. There is one (maybe it is a decoy) fuse that sits out in the open it was fine. But this fuse is next to the outlet wire on the circuit board was blown. It is small and covered with black shrink tape. This fuse is very easy to overlook. I unsoldered the ends and replaced the 12V 5 amp fuse. I used an inline fuse holder during replacement so if it goes out again I can just change the fuse. It is worth a look, good luck.
SOURCE: need ac adapter for drink o matic
I used the car adapter cable that came with it, and bought a Sunforce AC/DC Power converter (Model: JT-DC12V5.8A) for $20.
You can find these all over the place.
Diet Coke is also available in the following flavors:
Diet Coke cherry
Diet Coke vanilla
Diet Coke Green Tea
Diet Coke Lemon
Diet Coke Lemon Lime
Diet Coke Orange
Diet Coke Raspberry
Diet Coke with Citrus Zest
• Diet Coke Light Sango
