Question about Roland Music
When I turn my 4700 roland onthe light comes on but I have very little volume. Help me
In my gr 33 the volume is very low. mistakenly i did a factory reset after that the volume is becomes very very low. Any solution for this problem?
There is probably both a global volume and individual program violume as well. One or both may have reset to a lower level and need to be turned up. It's also possible that the general output has a setting for line level or instrument level, which may be software controlled. Take a look through your manual to find these settings and adjust to suit.If all else fails, contact Roland Customer Service at this link for help.
Roland Company Contact Us Contact Us
Sep 15, 2016 | Roland Gr33 Guitar Synthesizer
Sir i am from india i am purchasing roland bk5 since 1 year volume control of my keyboard does not work ...where should i buy that volume control plz help mee sir...
Might be best to contact the local service agent in India for Roland equipment.
Rivera Digitec (India) Pvt Ltd,
411 Nirman Kendra Mahalaxmi Flats Compound
(off Dr. Edwin Moses Road)
Mumbai 400011 Ph 022 24939051
If you do not have a user manual for this you can get it from
http://lib.roland.co.jp/support/en/manuals/res/62265052/BK-5_e4.pdf
Aug 06, 2014 | Roland Elektronische Musikinstrumente...
Roland troubleshooting
Are the speakers hooked up? volumes up? Is the guitar using active pick-ups? if so, is the battery good? is any noise coming thru the amo?
Jul 18, 2014 | Roland Ac60 Acoustic Chorus Guitar...
Hey I recently purchased a Roland TD-4 and i have no idea how to hook up an amplifier to it. My friend gave me a little amp, and i've tried many ports and cannot get it to play outloud. I'd like it...
First plug a set of headphones into the Left audio out and see if you get any sound from there... NOTE: it will only be in the left headset and this is normal. Turn up volume control... note the level will be low as this is a line output, not headset. This is a test to see if there is audio.
Sep 02, 2011 | Roland A: TD-4 Electronic Drum Set Pads,...
I have a very loud hiss/buzz sound coming from my Roland. It goes away if I lower the high volume knob. This just starred to happen recently. I tried changing connections from ch1-4 but no fix.
If this ties to a keyboard, make sure the keyboard and this are BOTH plugged into the same receptacle. You should send a higher level from the keyboard (turn volume up to around 70% or so) and use less volume at the input gain of this amp. Use more at master volume if the amp has one if needed. If the hiss is there with NO input cables plugged in and input gains at 50%, that is objectionable, the amp probably needs servicing. Unused channel gains should be clear down.
Apr 11, 2011 | Roland Elektronische Musikinstrumente...
Roland keyboard. Extremely static-y speakers. Cuts out.
It sounds like your volume slider is dirty. Try carefully and judiciously spraying a good quality contact cleaner into the slider and working it. do not use a lot. It only takes a little. Also do not use WD40.
Mar 01, 2009 | Roland Juno-D
Music Logo
35 people viewed this question
Top Roland Music Experts
Michial Gueffroy
Cameron Lewis
Cameron Lewis
Level 1 Expert
Thomas F. Schneider
Are you a Roland Music Expert? Answer questions, earn points and help others
