Question about Yamaha Music
Yamaha TF3 mixer... How to stop the ON buttons from blinking on the channels
HOWTO RESET mixer YAMAHA AW2400
I do not know what you mean by 'resetting'.
Here's the manual:
https://usa.yamaha.com/files/download/other_assets/9/335089/aw2400_en_om_b0.pdf
Dec 06, 2017 | Yamaha Aw2400 Aw 2400 Digital Workstation
Just bought the mackie 1604 vlz3 mixer and cant figure out how to get sound to the main speakers, the speakers and amps are connected correctly
Simplest is to use the LR button at the bottom of the channel strips you want to send to the main mix. Make sure you set the gain for each channel in use so that the clip light just occasionally blinked then back off a fraction.
If you want to use sub channels assign the strip to the appropriate one 1/2 or 3/4 and the assign the sub to the main mix and bring the subs up.
May 21, 2016 | Mackie 1604 Vlz3 16 Channel Mixer
I had major static sounds from my yamaha stagepas 500. I plugged in an acoustic guitar into the mixer while running a keyboard and 2 vocal mics. I started getting crackling sounds. I changed the patch...
Chances are there is nothing wrong with the mixer. IF you accidentally turned on Phantom power, that would cause the problem. Phantom is ONLY used with condenser mics and a few DI boxes. Turning it on can create noise unless balanced lines are used everywhere.
Jun 29, 2011 | Yamaha EMX512SC Powered Mixer 500 Watts...
My Yamaha MG102C has no sound, and all of the LED's are on. There's no inputs connected at all.
Correct me if I'm wrong, but if you have nothing connected as an input, you're NOT going to hear anything. I assume you can't get your inputs to get to main output fader(s), if that being the case, first make sure your gain knobs are up at about 12 o'clock position, your channel faders are up to 0 and then make sure "channel assignment buttons" are assigned to stereo outputs.
Mar 07, 2011 | Yamaha Mg102c Stereo Mixer
Problems with yamaha mw10c usb mixing desk i have a signal on desk but cubase is not picking it up and i can find no option in any cubase menu to read the usb audio
Make sure that in the control panel of Windows, "Sounds and Devices" under the "voice and recording" tab, the Yamaha mixer is shown as the device for both voice recording and playback.
Feb 04, 2011 | Yamaha MW10C 10-Channel USB Mixer
I have a YAMAHA GA 24/12 mixer and 10 aux (all) no
Check that you have the gains INTO the aux channel from each strip you want routed there turned up... AND... the gains OUT of the aux turned up. Two places to adjust the gains.
The AUX LIKELY use TRS balanced outputs... check that you are using those.
These are a starting point, I do not have a manual for this device.
Feb 11, 2010 | Yamaha Music
Effects button not working!!!!
Most likely the fuse for the effects circuit has blown, which happens sometimes on mixers with built in effects.
You'll have to open the mixer as the fuse will be inside the mixer on a circuit board (look around inside where the effects part of the mixer is) replace it with an identically rated working fuse and you should be done.
Apr 24, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
I need to know where you plug the guitar cord into the mixer
you plug it in to any channel you want just lick a mic.
there you go DFD
Mar 18, 2009 | Yamaha Mg102c Stereo Mixer
Music Logo
42 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
