The Pfaff 332 has a stop motion mechanism that is a small knob in the middle of the hand wheel. This disengages the needle and allows you to wind the bobbin without having to check on the material to be sewn. Hold the hand wheel so that it will not move. Turn the stop motion knob counter-clockwise (turn the knob all the way to the left). Put a second spool of thread (of appropriate weight and color) on the right hand pin. Lead the thread from the spool around the thread retainer clockwise. Pull the thread into the guide and then push the thread through the slot in the bobbin from inside the bobbin. Place the bobbin onto the bobbin winder spindle so that the key at the base of the spindle enters the slot in the bobbin. Press the lever into the bobbin. Hold onto the thread end and slowly start to wind the bobbin. After a few winds of the thread, break off or cut the thread that is above the bobbin. Continue winding the bobbin (at any speed). When the bobbin is full the lever will automatically move back to its original position. (If you do not need a full bobbin, move the lever when the bobbin is sufficiently full.) Remove the bobbin from the bobbin winder spindle and cut it free of the spool thread. Return the stop motion mechanism to the right by turning it clockwise while holding the hand wheel.
Pfaff has a manual for the 332-260 on their support page: http://www.pfaff.com/en-US/Support-and-Updates/Support . The link to the machine page is http://www.pfaff.com/en-US/Support/3421 . The current link to this manual is http://www.pfaff.com/SiteMedia/PFAFF/Products/Machines/Support-manuals/pfaff_332-260-manual-EN.PDF . See pages 13-14 of the manual for some pictures of the guides and levers.
I hope this helps.
SOURCE: timing my pfaff 332 sewing machine
There are two parts to the sew hook on that machine. The outer part has the hook point that grabs the thread off the needle. Then there is an inner part which has a post in the center of it that the bobbin case fits on to. The inner part should be held in place with an arm that has a bump on it. It keeps the inner part from spinning around. Sometimes this arm slips loose and a notch in the inner part of the hook assembly slips out from under the knob on the arm. If this is what is happening, you need to loosen the screw holding the arm in place and reposition the notch of the inner part of the hook back under the bump on the arm. There needs to be clearance between the notch and the bump for the thread to pass between the two. And the bump should be in line with the needle when it is in its lowest position.
If this doesn't solve the problem you need to take the machine in for repair.
Wayne
SOURCE: Anna had this problem with her Pfaff 332 sewing machine, I do too
I believe that the bobbin case holder has become unlatched, for lack of better terminology. I have one of these machines, and my first experience with one was exactly as you are describing. A friends grandmother brought it to me because it kept breaking needles and wouldn't complete a stitch.Put the bed table in the lowered position, leaving the free arm exposed. Remove your needle, presser foot, and bobbin case, leaving the bobbin door open. Next remove the two screws that hold in the feed plate, and remove the feed plate. Looking down into the bobbin area, manually turn the bobbin case holder. There is a small slot in the top of the bobbin case holder, look for it as you turn. A small latch protruding from the bed plate is supposed to be clipped into that slot, and if the latch is still there, you likely will not be able to rotate the holder into place: This is good news, it means nothing is broken. Loosen the three screws (two silver on the top of the bed plate and one black in the area where the feed plate goes) which hold the bed plate in place, but do not remove them. You should be able to lift the bed enough to get the holder into place, and then set the bed back down and tighten the screws. Reassemble everything, throw in a new needle and see how it goes!
SOURCE: The Pfaff 332 sewing machine is seized up
Well Wayne, If you can remove the outer cover of machine without a headache, then I would spray it with WD-40 and let it sit for a day and then try it again. It may also need to be timed.
SOURCE: my pfaff 1215 won't disengage when filling the
The problem is lack of oil underneath the balance wheel on the shaft, if you do not have an oil hole you would be advised to take it in for a service because the balance wheel needs to be pulled out slightly to oil it.
Testimonial: "Sounds like the answer is a good one, and since I don't know enough about it, it is going in tomorrow for a tuneup. Thanks a lot "
