Cell phones are drained by running background apps, LCD brightness etc. Here are a few tips to help you.
Most importantly, batteries do loose their strength (even when fully charged). I would possibly replace the battery every 2-3 years with a name brand battery, not a generic. Also keep in mind, when your phone is charged at 100%..unplug it.
Tips to save battery life
To save and extend battery life, follow these steps:
Lower screen brightness and timeout duration
From any home screen, tap the All Appsicon.
Tap Settings.
Scroll to 'DEVICE,' and then tap Battery.
Tap Brightness.
Touch and slide the Brightness slider left to decrease the brightness setting.
Tap OK.
Tap Screen timeout.
Select one of the following options:
15 seconds
30 seconds
Turn off Wi-Fi, Bluetooth, GPS, Portable Wi-Fi Hotspot
Tap Settings.
Tap Tethering & Networks.
Tap Mobile HotSpot.
Clear the Mobile HotSpot check box.
Tap the Back key.
Tap the Back key again to return to the 'Settings' menu.
Scroll down to 'PERSONAL,' and then tap Location access.
Clear the GPS satellites check box.
Touch the Status bar and slide it down.
Tap Wi-Fi to turn off.
Tap Bluetoothto turn off.
Change application sync settings
From any Home screen, tap the All Appsicon.
Tap Settings.
Scroll to 'PERSONAL,' and then tap Accounts & sync.
Clear the Auto-sync data check box.
To reduce sync settings for individual applications, select the desired application.
Turn off background data
Tap Settings.
Tap Mobile data.
Tap the Menu key.
Select the Restrict background data check box.
Minimize use of third party applications
Tap Settings.
Scroll to 'DEVICE,' and then tap Apps.
Select the application you want to edit.
Tap Disable to turn off the application. Note: You can tap Uninstall instead to completely remove the application.
Toggle from 4G to 2G
Tap Settings.
Under 'NETWORK SETTINGS,' tap Mobile networks.
Select or clear the Use only 2G networks check box.
Update to the latest software
Tap Settings.
Scroll down to 'SYSTEM,' and then tap About phone.
Tap System updates.
Tap Check now.
Follow any additional prompts.
Set device to sleep when unused
Press and then quickly release the Power key to set the screen to sleep mode.
To activate the screen, press and then quickly release the Power key again.
Hey Jenna lee, i got it to work so here is what i did. It was frustrating so i played with it a little here is the basics of what i did for android
Make sure you go to settings on your phone, then under accounts, click on google click on each email you have for syncing and then uncheck the boxes that say "sync google photos" and "sync picasa web album".
next..
1.I deleted all of my photos off of my facebook (i was going to delete facebook account anyway)
2. i had to uninstall facebook, then re install it again ....and right before it comes on it will ask you too syn contact/photos... select "no syn"
3. next i went to "settings" then "application manager" on my phone ... found the facebook app and cleared the data....
4. then i went to gallery app in application manager and cleared that data too.
5. then i uninstalled facebook again. 6. then i went to "storage" on my phone.. clicked on photos and then deleted all of my photos on there
7. i backed out and went back to application manager to see if my gallery app data was still cleared,.... if not then clear it again.
just make sure you are doing these things .. i was really playing with it, but those are the main places i was deleting at. hope it helped.
hope that it helped
iPubsoft iPad iPhone iPod to Computer Transfer is the best choice to backup the data betweent th apple devices, including iphone 3gs/ 4/ 4s/ 5s, ipad, ipod etc.iPubsoft iPad iPhone iPod to Computer Transfer
Hello and Welcome to FixYa!
This usually happens due to corruption in the user data, try clearing it first then syncing, to do so follow the steps; (May vary, but will be similar)
Go to "Settings" then Select "Applications"
Select "Manage Applications"
Scroll down to "Contacts Storage"
Click on "Clear Data"
Go back to to "Settings" again and in "Data Synchronization" re-sync by pressing "Synchronize Now"
Thank you for using FixYa!
If you think I was of help, your token of appreciation in the form of rating and a testimonial will be esteemed.
Concerned, Nooh
YOu can reset bios password with 2 method. (1) open back cover of
laptop then find motherbord .Pull cmos cell from motherbord for 15
minutes then again put it in it's position .then it not ask for
password. (2)You can clear password with jumper settings find jumper on motherbord named clear cmos it has 3 pin .1-2-3 Put jumper in 2-3 position then again put it in 1-2 position then check . Let me know if you need more assistance. Thanks.
You can use the BlackBerry Desktop Manager to synchronize your organizer data (calendar entries, contacts, tasks, notes, and memos) between your BlackBerry smartphone and your Mac computer.
In order to synchronize with Microsoft® Entourage, Apple® Sync Services functionality must be turned on in the Microsoft Entourage application. To accomplish this, complete the following steps:-
note:-Back up information and data before changing any settings on your Mac computer.
1) If the BlackBerry smartphone is connected to the Mac computer, use the Eject option to remove the BlackBerry smartphone from the Mac computer. 2) Close the BlackBerry Desktop Manager. 3) Open Microsoft Entourage. 4) On the Microsoft Entourage menu bar, go to Entourage > Preferences. 5)Within General Preferences, click Sync Services.
To turn on contact list synchronization, select the Synchronize contacts with Address Book and MobileMe check box To turn on calendar synchronization, select the Synchronize events and tasks with iCal and MobileMe check box
note:- When Sync Services has been enabled and the OK button is selected, a new dialog window appears with the following choices:
1)Replace Entourage items with Sync Services items. 2)Replace Sync Services items with Entourage items. 3)Merge Entourage items with Sync Services items.
For Additional Information:-
Before the BlackBerry smartphone data is synchronized with the Mac computer, verify that Sync Services is turned on in the Mac OS X iSync application. This is done by completing the following steps:
1)Open Applications on the Mac computer and click iSync. 2)In the iSync menu, click Preferences. 3)If necessary, select the Enable syncing on this computer check box.
hi,
u will not able to sync ur data into ur husbands profile for eg: as u know u would be having ur username on ur zire and ur husband will be having his so there is no way u would be able to merge both the data , what u can do is when ur syncin ur palm to outlook u can sync it with ur profile and when ur husband's sync 's his zire he can create a new profile and sync it , and if u plan of using the same username then , u would get an error sayin duplicate username is found ....
Regards
