There are lots of errors that appear in the canon printer. Some of those can be removed by performing troubleshooting. One of those errors is Canon Printer Error Code 1688 which is shown by your canon printer when the ink cartridges are exhausted. But, surprisingly sometimes this canon printer error code appears when there are ink cartridges as needed. There are various reasons for this issue.
It may appear because the ink is unable to pass through the sponge that makes your canon printer show the error message 1688. There are lots of ways to remove this issue from your Canon printer. One of those ways we are going to discuss in the mentioned blog follow them.
Canon Printer Error Code 1688 shows when the ink cartridges are exhausted. But, surprisingly sometimes this canon printer error code appears when there are ink cartridges as needed. Follow blog steps to fix errors easily. we are one of the best printer support bloggers.
For more method check this: https://vocal.media/lifehack/guide-to-fix-canon-printer-error-code-1688
It could be run out of inc
SOURCE: Canon PIXMA MP140 error code E 2
error E 2 =>
The machine is out of paper. / Paper does not feed.
Reload paper in the Auto Sheet Feeder and press the Black or Color button.
SOURCE: Canon Mp780 error code 6A00
6A00 is not a jam error, it is an error of the purge assembly not cycling properly. Many times a paper scrap jammed in the capping assembly or the squeegee assembly caught on the filter assembly. Usually worn out gears and dried ink so that replacement of the purge assembly is the best fix.
SOURCE: Error 5100 on my canon mx 310.
the 5100 is the carriage error and can be caused by 4 different sensors. First off the "Timing Strip" that passes through the back of the Carriage Assembly can be contaminated with ink spots and this needs to be cleaned. Open the cover and use your flashlight to examine the timing strip as much as you can see. You really don't have much access to this strip unless you remove the covers,..and doing that is considerable work. The other items that can cause this error are the sensor inside the carriage unit, the drive motor for the carriage asm, and of course the main logic card. However, 99.6% of the time it is the Timing strip which is easitly contaminated with splattered ink.
