Exercise & Fitness Logo
Brenda Shearin Posted on Dec 30, 2019
Assemble manual for truPace M120 treadmill. Electical wire pulled out of arm of machine while moving.
Denise Kearney
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 29, 2020
Denise Kearney
Contributor
Level 1:
Answers
Questions
0
Helped
117
Points
You might find the answer here https://usapeptides.info/
1 Related Answer
ercupa190
ernesto cuadra
  • 12223 Answers
  • Posted on Nov 25, 2011
SOURCE: wires under to 495cw treadmill can a loose
Dear Sir:
I thing was situation out of control.
Answer.
1) Do you now what wires cables are?
2)Where did you get loose?
3)Upper or lower wires?
4) There is a connectors or simple wires with colors?
please reply carefully for to Assist you.
Last questions: Would you please tell me exactly what is your model, mark,serial number of your Fitness Treadmill?. That will help us.
Do not worry. Take control, and will fix it.
sincerely.
E.CUADRA
MANAGUA, NICARAGUA.
Have moved it now coming up error 13
Hi There, sorry to hear,...when we move fitness equipment we often "pull, pinch, cut, nick, severe, pierce" wires from the upper electronics to the lower control boards. Treadmills that "fold" are a bit more tolerant of moving here and there. First, check that your cables are all connected and look fine. Then remember if masts were assembled as wires come loose in there as well. Finally, check for a speed sensor that should be counting revolutions of a flywheel or front roller of the treadmill. If you need further help you can email gregATbuyfitnessrepairpartsDOTcom for more help. Good Luck!
1helpful
Everything working except the belt
do you have the magnetic tag attached to you and the machine? it prevents operation unless its attached.
1helpful
Does Epic 425 MX parts can be removed? I cannot move the Treadmill in to my house due to too bulky for any door. Help!
Yes please see your instr. manual and follow the steps how to assembling and disassembling. if you do not have download for free
from www. fitness.manualsonline.com
God bless you
I have a NordicTrack SL710 recumbant bike that the pedals slip and make a clicking noise?
Prepareto oil by filling a grease gun with lithium grease. Check your owner's manualfor the exact type of grease for your unit.
NordicTrack SL710 pedals slip and make a clicking noise?
Kneelnext to the left side of the elliptical's base. Use the Phillips screwdriver totighten the two screws located in the center of the left pedal.2
Use theAllen wrench to remove the bolt securing the left pedal arm to the pedal legand body arm. Use the Phillips screwdriver to remove the screw securing therear end of the pedal leg to the crank arm.3
Pull theend of the pedal leg free of the crank arm. Wipe the crank arm clean, thenapply a fresh coating of machine grease or silicone lubricant. Replace the endof the pedal leg back onto the crank arm and use the previously removed screwto secure it back into place.4
Join thefront end of the left pedal arm to the ends of the pedal leg and body arm. Usethe previously removed bolt to connect the pieces together.5
Move to the right side of the elliptical and repeatthe above steps on the right pedal arm
1helpful
2answers
Reebok 11300 treadmill I have had decided to move the machine and in doing so the wires became disconnected, what colours go to what on the mains socket. The rest remained untouched. Is there a circuit...
The wiring diagram is under your motor hood in an envelope. Also look at the other end of the harness - the wires are in the same sequence. Just be sure to get all the insulation out of the connector before trying to reinsert the wire. Must insert wire with insulation on it. These are the red connectors I am talking about.
1helpful
I have a used Weslo Cadense 927 treadmill. I need to adjust the the tread, it's rubbing the side.
When you purchased the treadmill it came with an allen wrench to assemble the machine. That is the adjustment tool.
Inspect the rear plastic cap (the adjustment bolts are there) make sure it is not damaged. If the plastic is broken, it will need to be replaced. This job is not easy. If it is not broken, adjust the belt as follows..
If the belt is already rubbing, locate the adjustment screw at the back of the treadmill on the side that is rubbing.Adjust that screw tuning it 1/2 turn clockwise. Move the belt manually 3 full rotations.. If it is still rubbing, turn another 1/4 turn. Again move the belt manually 3 rotations. Once the rubbing stops, run the machine slowly and watch the belt from the back of the machine..
3helpful
Need to disassemble NordicTrack X7i trainer to move it. Don't have the manual
To get the manual go to iconservice.com and select the manuals link. You will be asked the model name or number. You can download a PDF file of the manual for free. Use the assembly instructions only backwards and you will be able to disassemble the machine.
1helpful
I am moving and my treadmill won't fit thru the door
Follow the steps from the user/assembly manual in reverse. Find the manual here:
http://us.home.lifefitness.com/resources/content/8/2/0/documents/T3%20Manual.pdf
Installation begins around page 9
Hello nordictrack has just stopped
Sometimes when these machines are assembled
a wiring harness gets damaged. If you have a manual, look at the diagram that shows the upright columns where the upper console mounts.
Look for the wiring harness coming out the top or bottom on the diagram. If it is on the right, the take the screws/bolts out of the arm that mounts to the upright and lift it up, just a little to see if the wiring harness is damaged or partly disconnected. If you cant see anything, then it is time to call a tech out to troubleshoot the problem.
Top Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
john h
ADMIN Andrew
ADMIN Andrew
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
