Cameras Logo
Diane Bates Posted on Dec 30, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I turn off the flash on my samsung TL205?
Tony Parsons
Level 3:
  • Samsung Master 6,405 Answers
  • Posted on Jan 01, 2020
Tony Parsons
Samsung Master
Level 3:
Answers
6405
Questions
Helped
1651859
Points
20272
Have you considered consulting the relevant page of the manual which would have been supplied with the camera when you purchased it ?
Samsung TL205 Camera turns on but the screen never shows any sign of light. Screen is not able to display anything. Can this model be reset?
Many times you can turn the screen off in the menu up settings. Some cameras have a physical button on the camera to do so. Look your camera over carefully, and read the menu settings in your manual. If you don't have that, scroll through all your settings and see if you've turned off the LCD.
tip
Samsung TL205 Battery Charger Samsung TL205 Charger
With the most high-quality camera battery charger,
Description: Home Travel Charger
Input Voltage (AC): 100-240V 50-60HZ
Car Input Voltage (DC): 12-24V
Output Voltage: 4.2V/8.4V
Output Current: 600mA
Dimensions: 1.86" x 3.33" x 1.50"
Weight: 2.5oz (85g)
Color: Black
Features:
A. Direct Plug-In wall Samsung TL210 Battery Charger - No cable necessary
B. Samsung TL210 Battery Charger Output: DC 4.2V 600mA
C. 110-220 Volts - Works in every country in the world
D. AC Car Adapter - Charge your battery at home or in your car
E. Fast Charger 800mA - Charges most batteries in 60-120 minutes
F. LED Charger Indicator - Red light: needs charging, Green light: charging is complete
G. Samsung TL210 Digital Camera Battery with Manufacturer's 1 Year Warranty.
H. The Samsung TL210 Battery Charger is for charging your battery only. It does not work as AC adapter for your camera
on Sep 21, 2010 • Cameras
I have a samsung TL205 and it wont come on.
This is Battery Issue, Charge the battery fully.
Also Wipe the contacts on the Battery and inside the Camera battery slot
It should work fine
Regards,
Suhail
1helpful
1helpful
Can I get a print-out manual for the Samsung TL205/PL100 Digital Camera
You may download the manual here. You can print it out yourself, or most office-supply stores can print and bind it for you.
1helpful
My Samsung TL205 digital camera will not turn on. The lens is out but when I press the power button, the green on button will light up then the camera will make one beep sound as the green light turns off....
I just fixed my camera. I pushed the lens inside completely. took the battery out and put it back in. turned it on and off a couple of times and ready to go!! good luck!
When ever I try to turn on my Samsung Dual View TL205 the green light just goes on then turns off. I've tried recharging already do you anything that I can do to fix this problem?
Try switching on by holding the button for about 1 minute .WITHOUT ANY BATTERIES IN CAMERA. Then replace batteries and switch on normally. (this should have done a camera "reset").
Worked for me on my camera!
Top Samsung Cameras Experts
ZJ Limited
ZJ Limited
Are you a Samsung Camera Expert? Answer questions, earn points and help others
