Question about Citizen Watches
I have a citizen eco-drive watch. It’s a aw7020-51a. It has a hand that tells you how much power it has. Mine is buried. I changed the “battery”’with no luck.
    Top Expert:
  • Citizen Master
  • 30,805 Answers
It is solar powered!
Posted on Dec 31, 2019
Anonymous
SOURCE:
Anonymous
  • 73 Answers
SOURCE: Setting the time on a Citizen Eco-Drive Watch
Go to this link and pay particular instructions on how to find your watches movement or caliber number.
http://www.citizenwatch.com/COA/English/settings.asp
Posted on Dec 31, 2007
Eric Mason
  • 161 Answers
SOURCE: Citizen eco-drive problem.
Hi Try www.citizenwatch.com for your manual of instructions.
Try Leaving watch in direct strong sunlight or under bright light for at least 12 hours.
Posted on Nov 02, 2008
Anonymous
SOURCE: second does not reset to 12
You should be able to solve this by pulling out the Crown(the one with which you set your normal clock), Pull it out in the 2nd stand.
Then by pushing the 'start/stop' button --> you change the minutes.
By pushing the 'lap/reset' button --> you change the seconds
It worked for me, took me a few minutes to figure it out, i hope this saves others the time of doing that :p
Posted on May 26, 2009
Anonymous
  • 23 Answers
SOURCE: Citizen Eco Drive second hand stoped working
The Citizen Eco Drive watches use special recharchable batteries.
I started collecting a couple of watches and I noticed sometimes a jeweler replaces them with an ordinary battery. The watch will work and at the same time it will try to recharge this one until it explodes! In newer models they made it harder to use the non-rechargable ones by adding a special connector or clip to the rechargable battery types.
Okay, if you say your battery goes bad, or watch does not run okay? It may have lost the charge over time. First thing to try is to leave it on the window sill so the dial is in the sun. It will start ticking, but please leave it out there for 3 days to a week. The seconds hand will tick irregularly in steps of one and two seconds, to show you it wants you to readjust the time, as it knows it has lost time. Adjust the time and it should run smoothly.
The seconds hand should run in single second steps, if it takes steps regularly, but every 3 seconds or so, it tries to tell you that its power level is going down. It will be able to continue for one or two days, but you should get it into the sun more often.
Charging the battery under a lamp is possible, however this heats up the watch and this may reduce battery life. As long as the watch keeps running I believe it should keep good time. It is quartz anyway. If this is not the case, and a good sunbath does not help, the mechanism could be running heavy, possibly due to overheating the watch; no help there...
If you need to know more about the Eco Drive, look for detail tech manuals for all types here: http://www.citizenwatch.com/downloads/tech/tech.htm
Those are great watches as long as you remember it needs light to charge.
Posted on Jun 25, 2009
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: i have watch citizen euro drive not abe to set
browse through my tips and you will find link for all Citizen watch manual downloads.
Posted on Oct 01, 2010
Citizen eco drive stopped working
Bad capacitor (Titanium Ion Battery)... probably a $30 or so repair on a fine watch.
Feb 17, 2014 | Citizen Watches Citizen Atomic Perpetual...
Just purchased the men's Citizen's Eco Drive Nighthawk (Black) ca0295-58e and the second hand on the watch is not ticking. I previously set the date and the hour and minute hands have moved, but not much....
Put the watch in any form of light for some time. Sun is best but not necessary. When the second hand stops running, it is a sign that the capacitor is low. The eco drive is a solar powered watch. When exposed to light, it converts the energy from the light and stores it in an internal capacitor which is really a battery that will last about 20 years.
Nov 09, 2017 | Citizen Watches CITIZEN Mens CA0295-58E...
Where can I buy an authentic (Ladies) Eco Drive WR100 Watch battery, in NSW please?
You can not, you need to send it into Citizen Watch Co. do not touch the rechargeable battery it should only be handled at the factory you will also void any future warranty with Citizen if you try to change it.
Aug 29, 2011 | Citizen Eco-Drive BL006056H Wrist Watch
Wath stopped
Eco-Drive powered watches can be finicky. They need a LOT of sun to initially charge the power cell, and then some strong light each day to maintain them charged. Put the watch in the window for a few days to see if it comes to life, if it does not the power cell may need replacement. Some of the earlier Eco-Drives used a capacitor that does not like to be run down from not being exposed to enough light, and will fail sooner than the newer power cells.
Jun 16, 2010 | Citizen Eco Drive Perpetual Calendar...
I have a Citizen, Blue Angel eco drive c300 caliberwatch with buttons on left that stuck Is this a fixable item
Sounds like it needs a cleaning like mine did. Go to stewarttime.com.
They are a Citizen Eco Drive repair shop. I can't say enough good things about them. They have repaired both my Eco Drives and I am a very satsified customer of theirs.
Feb 09, 2010 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
How to replaced a eco drive battery
The ECO series of Citizen's do not require battery replacement, as they are solar powered. If the watch stops due to a long period of non-use, there is a procedure in the manual as well as the Citizen website on how to get it running again. You will have to expose it to light for several hours (but not with lots of heat such as a car dash) to get it running. If you continue to have trouble, you may have a problem with the watch. I bought my wife a ladies ECO drive about 8 years ago and bought one for myself about 2 years ago and have not had a bit of problems with either. They are extremely good watches and it is nice not to have to worry about "when will the battery die?"
Jul 09, 2009 | Citizen Eco-Drive BL006056H Wrist Watch
Citizen Eco Drive
Okay,you stored your watch in a drawer as many people do? It may have lost the charge over time. First thing to try is to leave it on the window sill so the dial is in the sun. It will start ticking, but please leave it out there for 3 days to a week. The seconds hand will tick irregularly in steps of one and two seconds, to show you it wants you to readjust the time, as it knows it has lost time. Adjust the time and it should run smoothly.
Those are great watches as long as you remember it needs light to charge. Be sure to ask the watch repair man if he knows the eco drive uses special battery, if not sure, find another watch repair man before he kills your watch ;)
Jun 13, 2009 | Citizen Eco-Drive BL006056H Wrist Watch
May 31, 2009 | Citizen Eco-Drive BL5184-56L Wrist Watch
Okay, if you say your battery goes bad, did you store your watch in a drawer as many people do? It may have lost the charge over time. First thing to try is to leave it on the window sill so the dial is in the sun. It will start ticking, but please leave it out there for 3 days to a week. The seconds hand will tick irregularly in steps of one and two seconds, to show you it wants you to readjust the time, as it knows it has lost time. Adjust the time and it should run smoothly.
Mar 05, 2009 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
I HAVE A CITIZEN WATCH THAT THE GLASS IS BROKEN AND IT WILL NEED A BATTERY.THE NUMBER ON BACK IS 430076.WHERE CAN I GET THIS REPAIRED LOCALLY.I AM IN HARFORD CO.MARYLAND 21040.THANKS FOR YOUR HELP
Yes local watch service center near to your place can change the glass,tell the technician that is a mineral glass a scratch proof.
About the battery your watch has no battery it is a self powered, that's why they called it eco -drive,that is the features of your watch.
There's like a dynamo inside when you move, it produce electricity and stored it in barrel like a battery cell,the electricity stored there expired in two weeks ,if ever you don't use your watch,you better use so it can stock many electricity.
if my answer help you understand the problem rate me as FIXYA.......thank you in advance
Jul 02, 2008 | Citizen Eco-Drive Silhouette EW869452D...
Watches Logo
44 people viewed this question
Top Citizen Watches Experts
Janelle Schoonover
Janelle Schoonover
Ekse
Marvin
Marvin
Are you a Citizen Watch Expert? Answer questions, earn points and help others
