SOURCE: the orange idicator light is flashing.
Replace the batters and used the correct battery charger, Not a car charger.
SOURCE: DOESNT MOVE CHARGED WHEN TURN ON ALL LIGHTS COME
The motors are not getting power. Check to see that the chair is not in freewheel mode. Also check all the wires to be sure that they are connected properly.
SOURCE: all lights are flashing, and chair won't move when I try to use
The flash codes for the VSI controller used on this chair are located here:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
These will tell you what the fault is; repost with more information.
SOURCE: The wrench symbol comes up
The wheel chair has been driven under heavy load for extended period of time.
Leave joystick on and allow time for the electronics to cool down.Also remove the battery for 10 minutes then reinsert it and see.------------ Also if you require manual for your chair,please click on the link below:---http://www.rentascooter.com/downloads/_manuals/invacare/Invacare%20Xterra%20GT%20Owner's%20Manual.pdf
If the service light is flashing on the panel,then count the number of flashes and see the error as per that.
----------- This should help.Thanks.Helpmech.
