SOURCE: Finepix stucked in USB MODE
try taking out the battery and the memory card on your camera, then reinstall everything and turn it back on. lets see if that will help..
SOURCE: i have a jazzy 1121
Doggy count the number of flashes ie 4 flashes pause 4 flashes if you are not getting any pauses
what lights are flashing the battery level lights or the speed lights? Are all the battery level lights flashing or there are 3,4,5,6 or 7 etc. lights flashing? if you are getting a pause between flashes the number of flashes will tell you the error. Your owners manual should tell what each code means. Hope this helps
SOURCE: none of the touch sensitive
Stupid question but have you tried cleaning the buttons?
The buttons may not be touch sensitive, they maybe electrostatic (same as most smartphone screens where they need something that conducts electricity like a finger to work) and that they are not making good conductivity.
Its just an idea thats all.
SOURCE: My EMS 9 massage chair
The massaging is done by small motors with eccentric weights attached to the shafts. Those motors are controlled thru a very simple control board that in your case appears to have failed.
To fix the chair you will have to access the board and find out why it has failed - at least a basic experience in electronics is required, to perform the tests on the relays and triacs used to control the motors. If you don't posses this experience then all you can do is to check that the power cable, the remote cable and the motors cables that plug in the board are firmly inserted - for everything else you will have to call a pro.
SOURCE: Why is the power button on uAstra2 remote flashing and won't work?
OSIM uAstro2 Review Massage Chair Review try a different plug that has nothing else connected to it,,your manual,
http://www.brookstone.com/webassets/pdf/792590p_manual.pdf
