Without its' original remote control; you can't unlock it. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer of your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a compactable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site https://electrohelponline.blogspot.com/
https://remotesearch.blogspot.com/
https://elektrotricks.blogspot.com/
https://homenol.blogspot.com/
Type in the brand name of your device in the search box, and hit enter to get gathered related posts. See the website either in Webview with a mobile, or by a desktop computer. Mobile view has no search box.
SOURCE: Hisense LCD Tl2020
I, also, have the Hisense LCD 1504 and cannot turn it on with the original remote. I have to use the ON button on the side every morning. You have to hold this button in for a while then wait a while and presto, the blue button shows on the front and the picture comes on. If it fails to work the first try, just try try again. It does work for me this way. We had this same experience with the TV in our room at a Hotel where we were on vacation and the TV worked fine when we turned it on using the side ON button. It just takes a while for the picture to appear. Hope this clue will help someone.
SOURCE: parental control locked how do I unlock them RCA model 13V420T
hello!if nobody "tweak" your codes, try 1111 or 0000. You need to be able to access "menu' off your remote control. Make sure, universal remote matches the manufactures. Better odds to hit "menu". good luck,Alex.
SOURCE: Antsig AP593 Universal Remote Control Code for Sanyo LCD-40XR10F LCD TV
Hello
Try these codes.
004/ 013/ 049/ 108/ 110/ 180/ 209
0049 0097 0110 0004 0268 0012 0108 0180
Direct Code Entry
Contact Sanyo or use Google with that model number "original remote"
Note: Sanyo and Fisher are same company.
SOURCE: HOW DO I REMOVE CHILD LOCK ON A SANYO TV 24K40 MODEL WITHOUT REMOTE CONTROL
Unfortunately unless you can access the settings menu from the TV buttons you will need the remote control!
