Press POWER to turn the washer off.
Unplug the washer from the power outlet or turn the circuit breaker to the unit off.
With the power disabled, press and hold the START/PAUSE button for 5 seconds.
Plug the washer back in, or turn the circuit breaker back on.
Suggest you test the wall receptacle with some other known good appliance e.g. vacuum cleaner.
SOURCE: Error code PF
THIS is a "Power Failure " Clease the code (press Cancel button) and see if it starts up
PF means Power Failure!
Unplug both units for 10 minutes, then plug them back in and try operating them. You may need an electrician to investigate why you are losing power to both units
SOURCE: my LG front load washer won't spin! Has code OE or
Check the door lid switch. Maybe it's not closing good. Try to stick a screwdriver in the switch.
Thanks
SOURCE: My Lg washer is showing a code UE and then PF what
UE means that the load is unbalanced in my LG. The code PE means that the water sensor is malfunctioning and needs replacing.
SOURCE: whirlpool duet gas dryer PF error will not reset as per manuals
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
